Old 07-31-2015, 07:44 PM
JRC99's Avatar
JRC99 JRC99 is offline
Default Grandfather's 67 SS Chevelle.
I figured it's time the Chevelle got its own topic. This one won't see many posts for a while however, since it runs just fine except for something killing its battery and it can't be driven thanks to the tires. We just got a new grille emblem and door mirror for it. Trying to persuade the dad and my Pappaw to get it the new tires it needs.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Attachments - The Supercar Registry summitt.png IMG_20201007_135612354_HDR1500.jpg grt-701.jpg ChevelleC1500wheel.jpg
Old 07-31-2015, 08:10 PM
Default Re: Grandfather's 67 SS Chevelle.
If you're talking an unknown battery drain and unless you've already tried this, the below may help get you closer.
Pull the Neg battery connection and put a test light between the Neg Clamp and Neg battery post.
If the test light bulb lights up, indeed something's draining it.
Leave it connected w/ test light on and pull the fuses one by one until test light goes out...this indicates the culprit circuit.
Reinstall fuse and hook battery back up then investigate all items powered by this identified circuit.
Good luck!
Old 07-31-2015, 09:57 PM
PxTx's Avatar
PxTx PxTx is offline
You can also check the alternator for a bad diode. Common source of a drain, even though the alt can charge (though at 1/3rd reduced capacity).
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/xgikeXt91vM"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/xgikeXt91vM" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Paul III
Old 07-31-2015, 10:19 PM
JRC99's Avatar
I'll have to check this stuff. Right now my main concern is the tires. They're about as old as I am. Charge lasts long enough for how we'd use it for now anyway.
Also:
1995 Ford F-150 XL
Old 07-31-2015, 10:31 PM
PxTx's Avatar
I hear you on the tires, but they cost money. Diagnosing your drain is free and can happen in the time ut takes to get tires and install them.
Paul III
Old 07-31-2015, 10:56 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
you're not driving that beauty because of tires??!! get on your local kijiji and find some cheap used BFGs...gorgeous car.
I ain't nobody, dork.
Old 08-01-2015, 01:45 AM
JRC99's Avatar
1. That'd be craigslist. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
2. You'd not be driving it on them either. Badly cracked where the tread meets the sidewall. I'm trying to convince them. Pappaw's ok with it, it's Dad that is the roadblock.
Also:
1995 Ford F-150 XL
Old 08-01-2015, 05:27 AM
JRC99's Avatar
This is not my grandfather's first Chevelle. Back in the late 80s he had a '68 blue post car with a 6 cylinder. He pulled the six, and dropped in a 425 horse 350 he built along with a saginaw 4 speed (the one I asked about). He put a Posi with 3:55 gears in it too. Exhaust was a pair of glasspacks. He sold it and kept the motor and trans. The 350 went into an 83 Z28 he had, and was backed by a reverse manual valve body 3 speed (TH350 or 400, not sure which) that had 4:10 gears and glasspacks. That burned to the ground and the motor and both transmissions sit in his garage. Unfortunately I don't have pics of the 68 Chevelle. Kind of funny how he had a Red Camaro and Blue Chevelle in the 80s, and now he has a Blue Camaro and a Red Chevelle. Actually, he's owned this Chevelle since 1997. The Camaro came home after restoration October 23, 2004. He had the 68 Chevelle somewhere around 1987. I have receipts for parts from when he built the 350 from '87. Just felt like sharing this. I'll ask him if he has any pictures of the '68 soon.
Also:
1995 Ford F-150 XL
Old 09-26-2015, 07:06 PM
JRC99's Avatar
Scanned some old pictures of the mural it had. Pappaw didn't really like it (nor do I, I usually like murals, I just don't fancy this one) and as you can see it needed bodywork anyway.
Also:
1995 Ford F-150 XL
Old 09-26-2015, 11:07 PM
Do you realize how <span style="font-weight: bold"><span style="text-decoration: underline">OLD</span></span> you are making many of us feel when you are talking about your <span style="font-style: italic"><span style="text-decoration: underline">grandfather's</span></span> cars? [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Just teasing you, thanks for posting. I was never a fan of murals, but I can definitely relate to the time when stuff like that was popular!
Bill Pritchard
wrench (10-02-2017)
