Old 09-26-2023, 10:19 PM
TimG TimG is online now
Wow, looks super.
Old 09-27-2023, 02:27 PM
----Damn, that Beemer is beautiful!!!....Bill S
Old 09-27-2023, 03:35 PM
Hate to be "that guy" Bill; but.... a "Beemer" is a BMW motorcycle, and a "Bimmer" is a BMW car.
Does it matter in the grand scheme of things? Probably not.
Mark Twain, when speaking of himself in the third person, stated: "Well, also he will notice in the course of time, as his reading goes on, that the difference between the almost right word and the right word is really a large matter—’tis the difference between the lightning-bug and the lightning."
Twain later acknowledged some semi-plagiarism from his good friend, Josh Billing, who had said something similar many years earlier.
olredalert (09-27-2023)
  #824
Old 09-27-2023, 07:33 PM
Originally Posted by bashton View Post
OK fine; Kelly will be there too!
Bashton
Old 09-27-2023, 08:52 PM
mssl72's Avatar
mssl72 mssl72 is offline
All I can say is... wow, what an accomplishment!!
Is the Ferrari running yet??
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 09-27-2023, 10:44 PM
----I am truly humbled, Lynn!....Bill S
Old 09-28-2023, 02:17 AM
Well, you shouldn't be. Common mistake.
Old 09-28-2023, 02:56 AM
Glorious! What an accomplishment. Thanks for taking us along on this sweet journey!
Old 09-28-2023, 04:43 AM
427.060 427.060 is offline
"I’m not overly happy with those door panels based on the placement of the window crank. I’m thinking after all is said and done and then car is disassembled for paint, I may install power windows to eliminate the regulator and move a “dummy” crank handle to the correct position allowing me to make another arm rest to the proper length. I know they make switches that you can mount a window crank on which gives the appearance of the manual window yet is the power window switch under it. We’lll see."
How much trouble would it be to make the window crank be the power window switch? Maybe you could put contacts inside the door panel so that if you move the crank up a little bit the window goes up and move down to lower the window. Just a thought.
1968 Beaumont SD396
The Following User Says Thank You to 427.060 For This Useful Post:
PeteLeathersac (09-29-2023)
  #830
Old 09-28-2023, 10:44 AM
Ryan1969Chevelle's Avatar
I will be crawling all over this gem at MCACN!!!
Visually crawling, no scratches!!!
Ryan W31
dykstra (09-29-2023)
