Go Back   The Supercar Registry > Sponsors > Vintage Musclecar Parts
Old 10-24-2016, 05:57 PM
VintageMusclecar's Avatar
VintageMusclecar VintageMusclecar is online now
Default Re: When it rains...it pours.
The heads are at the machine shop, and here's the initial assessment: it appears to have been nothing more than a fluke failure.
Installed height was verified to be ample so there was no coil bind and the guide appears to still be good. However these springs were a bit shy on open pressure for the HR cam, so they are being replaced with a set of PAC 1201's. I'm also scooching up (technical term) the installed height a little bit so I can re-install the 1.6 rockers again--which will bump the net lift from .488"/.509" to .520"/.542".
On another positive note, it turns out the guide wasn't cracked after all, I was just seeing where the replacement guide was protruding through the casting.
The new parts will be here tomorrow, and my machine shop said he should be able to have the heads back together by the end of the week.
Note: I could've done this work myself since it's nothing more than simple parts replacement, but I wanted him to check the seat for me so it could be touched up if necessary, and also just to clean the heads up again.
Fingers crossed for decent weather this week.
Man what a relief.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
<span style="font-style: italic">Click the banner below!</span>
sales@vintagemusclecarparts.com
(937) 836-5927
Check out the new Vintage Musclecar Parts
Facebook page!
Old 10-24-2016, 08:36 PM
earntaz earntaz is offline
Yenko Paid Member
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Eric -- have you ever heard the saying ... &quot;ducked a bullet&quot;?? WOW -- a skoshi more throttle and suck the valve ... TAZ [img]<<GRAEMLIN_URL>>/beers.gif[/img]</div></div>
Repeat!!! [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 10-24-2016, 10:33 PM
SS427 SS427 is offline
Yenko Paid Member
Glad to hear it was nothing major. Nice turnaround time too so you should be able to go before the snow flies.
http://www.youtube.com/watch?v=62r-6vgk2_8
specializing in REAL LS6 Chevelle restorations
Old 10-26-2016, 11:45 PM
novadude novadude is offline
That's god telling you it's time to dump the 45-50 year old iron and get a better performing set of Vortec heads on that SBC! [img]<<GRAEMLIN_URL>>/wink.gif[/img] LOL
Those are 041s?
Old 10-27-2016, 12:04 AM
I was trying everything I could thing of to figure out a way to swing a set of aftermarket heads, but it just wasn't in the budget right now.
They are 041 X heads--mildly ported with 2.02/1.60 valves. They've been on a flow bench and do out-flow Vortec heads.
As I mentioned in the build thread, I tried to find a pair of Vortec heads to test against these 041's on the dyno, but out of the 3 pairs I located there was only one good (read: &quot;not cracked&quot casting out of the bunch. Buying a new pair of heads just for dyno testing wasn't in the cards, so that test got axed.
Carburetor Rebuild &amp; Restoration
Engine &amp; Driveline Parts &amp; Services
(937) 836-5927
Facebook page!
Old 10-27-2016, 01:16 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">I was trying everything I could thing of to figure out a way to swing a set of aftermarket heads, but it just wasn't in the budget right now.
As I mentioned in the build thread, I tried to find a pair of Vortec heads to test against these 041's on the dyno, but out of the 3 pairs I located there was only one good (read: &quot;not cracked&quot casting out of the bunch. Buying a new pair of heads just for dyno testing wasn't in the cards, so that test got axed. </div></div>
I'm guessing they have some work if they out-flow vortecs. My 062 castings (the new Hencho en Mexico ones for $600 pair, assembled) went 227 cfm @ 0.450&quot; on a reputable shop's bench. Stock 041s don't flow like that. [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Flow isn't everything either... the 041 vs. Modern Vortec chamber is night and day.
If I had a set of 041s, I'd use them too. I still remember hunting 041s/462s in the late 1980s / early 1990s when they the best thing going (and also rare and expensive). Things sure have changed in the SBC world.
Old 11-30-2016, 05:47 PM
Zman1969 Zman1969 is offline
Yenko Paid Member
lucky that the damage bill wasnt worse! I just fixed my wifes suburban 99 Vortec 350 it had a severe misfire #4 after checking had 0 lbs compression on that cyl. I removed valve cover to find the exhaust pushrod bent and disloged then I noticed the spring was still compressed, WTH? I rapped on end with a drift to see if it would seat with no luck, valve stuck open-when I pulled heads it had one bent exhust valve. I have no idea what caused it to bend? I saw no mark on piston but it had to hit it, I mean what else?
69 RS/Z 302 VE3 Daytona
69 Nova SS 396
Old 11-30-2016, 07:29 PM
Yenko Paid Member
thoughts anyone?
69 Nova SS 396
Old 12-01-2016, 08:38 PM
Looks like it just hung the valve in the guide.
Any damage/issues with that lifter or rocker arm?
(937) 836-5927
Facebook page!
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
