What other years used xt wheel? I know 69 Camaro, Firebird & Nova. What else?
The reason I ask is I have a K11 dated 11 10. Thank you, Joe
1968 Z/28 Corvette Bronze. Black Hounds Tooth. 02E Los Angeles born 3/13/1968 pnt OO 1969 SS396 Yellow/Yellow 08E Norwood born 8/28/1969 pnt 76E 1970 'cuda Moulin Rouge, 440-6, 4 speed Last edited by X66 714; 05-27-2017 at 02:14 PM. |
70 Olds Cutlass, 70 Nova.
...................... John Brown This isn't rocket surgery..... |
they are on 69 and 70 W31 and W30 Olds also..easier to find there, but not really less expensive
!!!treed.....again
Mark |
I don't think I have ever seen one dated newer than 69. Just learned something new.
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner Last edited by Jonesy; 07-15-2017 at 02:10 PM. |
Maybe a GM replacement?....Joe
i dont know about Novas, ive never seen one, but i have owned a couple off a 70 W31..theres a w30 owned by a guy on classic oldsmobile thats been documented with XTs...its a 2 owner survivor and they where on there day 1...BUT...always on early cars..so maybe ran til they where gone on the lines...dunno, but the 70 442 guys are always desperately seeking them
if i remember correctly..Stefano bought the car off ebay...and its the car with XTs,,hes here all the time ask him...i think he even uses the car as an avatar arent FC the replacement? or some similar code? just cant remember anymore
Mark |
I own 2 XT wheels with 70 dates. A used one dated K10 4 16 and a NOS one dated K10 4 17. Would the XT's used on Pontiacs or Olds cars use a different digit in the position after the K to designate which division car it was made for? If this is true, wouldn't my 2 wheels only be originally used on a 70 Nova? I knew that the 70 Camaro didn't use that wheel code as I own 4- 14x7 steel wheels that I know came off a 70 Camaro L78. I don't have access to those wheels at the moment but if I remember correctly it seems the code was AB or something else that started with an "A". I'd like to trade the 2 XT wheels listed to someone who has a pair of the same, dated K19 1 30 XT.
Loren
67 RS L30 3sp 10C LOS 69 RS/SS L78 M22 02D NOR |
Loren, The number next to the K designates the Kelsey Hayes plant. Your NOS XT wheel would be deciphered as follows:
K: Kelsey- Hayes designation 1:Plant: 1= Romulus Michigan 2= Windsor Ontario Canada 3= Philadelphia Pennsylvania 0: last digit of year, in your case 1970 The 14×7 steel wheel that came on the Super Sport Camaro's in 1970 were coded CL. This info is from the Chevy by the numbers book. I hope this helps, Rob. |
Thank you. I had it in my head that the "1" meant Chevrolet but in thinking about it, that really doesn't make sense but designating the plant does. Yes, I bet that 70 wheel code is correct. It's been along time since I looked at them. Any idea what was different in 1970 that the Camaro had a CL code 14x7 steel wheel and the Nova received an XT 14x7 steel wheel?
Thank you again. Loren
67 RS L30 3sp 10C LOS 69 RS/SS L78 M22 02D NOR Last edited by camaro cat; 05-28-2017 at 04:06 AM. |
i know the XT is a 14 X 7 but what is the specific back spacing for the XT wheel? Thank you.
The Following User Says Thank You to chris slawski For This Useful Post: | ||
Jack (11-07-2018) |
