Old 04-12-2022, 01:27 AM
subyman99 subyman99 is offline
Default 67-68 z28 with cragar fronts (hitting calipers)
Hello! I recently picked up a nice set of 4” skinny cragars for my 67 z28 for a little change on the look of the car. Little did I know, they hit the brake calipers. Without messing with the car, has anyone had success with spacers ? I’m sure this has been ran into a lot with the big disk Brakes on the early Camaros and these wheels.
I appreciate any help
Matt
1967 Z28 survivor Black original drivetrain
1968 Z28 survivor white 40k miles
1969 Z28 survivor Rally Green 60k miles
1969 Z28 survivor Rally Green 20k miles
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Berger copo original paint 240 miles
Lots of 67-72 Chevrolet trucks
Old 04-12-2022, 02:24 AM
fiveforty fiveforty is offline
Yes, use a spacer but use a longer lug nut that goes thru wheel and spacer. I forget but i think the spacer is around 3/8 or 7/16.
Old 04-12-2022, 09:38 AM
I've had to make a few spacers for my car when changing wheels. How much do you need to clear the caliper? You can use washers to figure out how thick the spacer needs to be.
Big Block 69 (04-15-2022)
Old 04-12-2022, 10:17 AM
1967 4K's Avatar
1967 4K 1967 4K is online now
Matt, search back here on the site. This has been discussed a few different times. It’s not that much work you just have to do some proper measurements.
Richard
1967 Camaro SS 396/375 4K
Old 04-12-2022, 11:45 AM
bergy's Avatar
bergy bergy is offline
I had the same problem on my 67 L78 Camaro. Had to use a big spacer & I wasn't happy with thread engagement using stock studs. Sold the Cragers! They did look cool though :-)
Old 04-12-2022, 12:11 PM
napa68 napa68 is online now
I texted Matt already about the subject. For any other members that are interested, I am doing the same thing on the HM 68 I got back (another set of wheels and tires). I think I have found the right combination of spacer and lug nuts. I'll update when I know more.
Tim
Old 04-12-2022, 07:25 PM
Chuck_Burg's Avatar
You can see I did the same thing on my 67. I have a 3/8" spacer. Combine that with longer wheel studs and mystery solved. All the bite you could ever want from your lug nuts. I had direct 5 on 4-3/4 spacers made by a machinist, you can find generic ones at auto parts stores and online but they just didn't sit right with me...
Old 04-12-2022, 07:56 PM
scuncio scuncio is online now
I bought these to run Cragars on a 67-68 with the 4-piston front discs. Nice quality. I'm pretty sure these came with only a single bolt pattern, not the dual bolt pattern as shown in the picture below:
3/8" Wheel Spacers, 4.75" Pattern
markinnaples (04-12-2022)
Old 04-12-2022, 08:27 PM
Chuck_Burg's Avatar
Those look nice Tony, much better than universals I found.... They look just like the ones I had made other than the extra holes.
