#1451
Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
I love it !!!!!!!!!!!!!
Very specific, detailed, instructions!!!! I like the big smile on the bushing installation technician/BFH operator :-) Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
#1452
That picture is before the BFH hit his thumb.
Jason |
#1453
With this method.....YOU ARE GOING TO NEED ANOTHER SET OF HANDS......TO AVOID SCRATCHING.....with a hydraulic press.....it's it so much easier. You do not have to fight with the a hand held press.....and or having the control arm move around or perhaps fall out of your hand. JUST SAYING.
SEE IF A LOCAL BUDDY HAS A PRESS YOU CAN BORROW for a few hours. Save yourself a bunch of time and aggrevation. <span style="font-weight: bold">EMAIL SENT</span>. Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
#1454
Ryan.....is not that skinny [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
#1455
Shinny:-) FUNNY:-(
Terry offered his press, the cups I make up will work even better in the press and as you mentioned much more controlled:-) Ryan
#1456
Nice....use the press....much better results [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
#1457
Ryan
Weather you use a press or clamps, ensure your control arms are free of paint or powder coat on the mounting surfaces. Next place all bushings in the freezer overnight or 2-3 hours before installation. This shrinks the metal enough for an easy install. It also helps if the metal can be warmed up enough to expand yet not too hot to touch.
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
#1458
Great advice, thanks Paul
They masked off all the bushing surfaces except the upper "ears" on the rear end housing, should I sand this off? Ryan
#1459
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Great advice, thanks Paul
They masked off all the bushing surfaces except the upper "ears" on the rear end housing, should I sand this off? Ryan </div></div> It will be fine....if there are any small metal burs....be sure to file them away.....or use a power grinder, just BECAREFUL. Dan
#1460
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Great advice, thanks Paul
They masked off all the bushing surfaces except the upper "ears" on the rear end housing, should I sand this off? Ryan </div></div> It will be fine....if there are any small metal burs....be sure to file them away.....or use a power grinder, just BECAREFUL. Dan </div></div> Perfect:-) Ryan
