Old 06-19-2015, 06:01 PM
cook_dw cook_dw is offline
Banned
Default Re: Grandfather's 68 SS Camaro.
Is the Chevelle engine using the same cam, heads, intake, exhaust as the Camaro? If not then it needs to be tuned to the engine its bolted to..
Old 06-19-2015, 11:21 PM
Ignition advance not working or vacuum advance hooked up improperly?
Jason
Old 06-20-2015, 01:12 AM
JRC99's Avatar
JRC99 JRC99 is offline
I honestly don't know. Cam heads and intake are all different. I'm just trying to find the easy way out. I think I'm going to have to put the Camaro on the back burner while I learn how to do it, because my dad isn't all that good at tuning carbs (his words, not mine).
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 06-20-2015, 04:03 AM
JRC99's Avatar
I should note we tried to tune the carb with my grandfather once, but it didn't work very well.
Also:
1995 Ford F-150 XL
Old 06-20-2015, 04:25 AM
PxTx's Avatar
PxTx PxTx is offline
Post some data.
Degrees of initial timing at idle without vac adv hooked up?
total timing @ 3000 rpm without vac advance hooked up?
timing at idle with vac advance hooked up?
What pulgs? Plug gap? What distributor? Any ignition box?
Paul III
Old 06-20-2015, 04:33 AM
JRC99's Avatar
I'll have to ask. I just know i has an Accel distributor (MSD cap. No ignition box.
Also:
1995 Ford F-150 XL
Old 06-21-2015, 12:37 PM
JRC99's Avatar
I found an old distributor in the garage. It has an Accel cap, but apparently it's the original points distributor for the Camaro. Part Number HI HI2168 8b1 (or 3b1, or 3BL, or 8BL, I can't tell). Will this work on a small block. Pappaw said it was big block specific, but I don't know why it would be. He's got a 350 in his garage I plan on using in whatever car I get, and I'd really like to save 200 bucks by using this. (Y'know, so I can put said cash towards a tunnel ram for said 350. [img]<<GRAEMLIN_URL>>/naughty.gif[/img])
Also:
1995 Ford F-150 XL
Old 06-22-2015, 01:09 PM
68l30's Avatar
68l30 68l30 is offline
1112168 should be the number on it...350 SBC
BIG
Old 06-22-2015, 02:05 PM
JRC99's Avatar
Appears to be it. Makes we wonder what it was doing on a 396.
Also:
1995 Ford F-150 XL
Old 06-29-2015, 01:06 AM
JRC99's Avatar
http://www.summitracing.com/parts/msd-8910/overview/ Will this work with the Camaro's Accel distributor? I ask because it says it's for MSD Blaster ignition, which the car doesn't have.
Also:
1995 Ford F-150 XL
