Go Back   The Supercar Registry > Classified Section > Supercars/Musclecars-Wanted
Old 04-20-2024, 02:15 AM
Lynn Lynn is online now
Ryan, I don't remember seeing the mileage on this one, but my original cats on my 6.0 made it to about 230,000 miles.
Ryan1969Chevelle (04-20-2024)
  #82
Old 04-20-2024, 02:52 AM
On the 7,000 gvw trailer, ask if You can get it with load range D tires. They usually come with C's and they barely meet the gvw at 1,750 lbs load rating each. I run load range D on my 7k trailer at 2,200 lbs capacity. This gives you some leeway on weight and a cooler running tire. When loaded with a 3,600 lb car they are more stable against side wind and sway than the C's too.
  #83
Old 04-20-2024, 03:43 AM
67since67's Avatar
Originally Posted by Ryan1969Chevelle View Post
I started looking at trailers…….
I like to understand all options before move ahead with any large purchase and although I see a lot of 24’ 9900 lb GVWR trailers at events there is a low cost alternative that seems to meet any needs I have or will have in the future.
20’ Long, 8.5’ Wide, 6.5’ High,
Two 3500 lb axles, 7000 GVWR
Payload 4000 lbs
V nose
Brand new these are the same price as a used larger more heavy duty trailer which seems enticing.
Lower cost, more manoeuvre, better gas mileage, brand new, 3 year warranty, made in Illinois, hmmm….
I have a spending cap but this has me thinking…..
Ryan W31
What Mitch said on tires!...but to go one further I run Load Range E tires on 5400 lb axles. The new Good Year trailer tires are speed rated for 80mph. If you are going any distances today's interstate's will pound a trailer to death!
20' with a wedge is just fine unless you're hauling Impala's or bigger.
Stated you have a budget, but get it right and you have a trailer for life. Good luck with whatever you do!!- Bill W
  #84
Old 04-20-2024, 10:40 AM
Ryan1969Chevelle's Avatar
160K miles 266K kilometres.
One day I want to add a stainless exhaust with high flow cats and just a little bit more rumble but not very much.
Ryan W
Old 04-20-2024, 01:52 PM
I have to make a correction to what I said. I had my travel trailer in mind with the load range D tires. I do run E's on my car hauler 205/75x15 radials with 2,800 lb capacity and 80 mph rating. I have never run that fast with my 5.3. I would need a 100 gallon auxiliary tank in the bed to keep that up for long.
The 5,400 lb axles puts him back in the 10.k gvw category, which then requires a heavier frame, etc.
I do have a question...is the 20' plus the 3' wedge ? Also, an escape door would be a very worthwhile upgrade if ordering.
  #86
Old 04-20-2024, 03:00 PM
A few votes against the 7000 lb trailer………
I appreciate the feedback!!!
I think the best case scenario is to find a 2-4 year old 9900 lb GVWR trailer. (This would likely be a 24’ as they are much more common.
20’ is the cube, the V is in addition
Escape door is great but I am stretching to buy a trailer and need to keep this as low cost as possible.
Ryan W31
olredalert (04-21-2024)
  #87
Old 04-20-2024, 09:15 PM
Donnie's Avatar
Donnie Donnie is offline
Ryan, I know your on a budget, but I would get everything you want on the trailer. that way you only buy the trailer one time instead of twice.
if I would have got the wide body and escape door the first time. I wouldn't have bought the second trailer.
69 SS L78 Chevelle
70 SS 396 Chevelle
The Following 2 Users Say Thank You to Donnie For This Useful Post:
69M22Z (04-22-2024), Ryan1969Chevelle (04-20-2024)
  #88
Old 04-23-2024, 10:45 AM
I have looked at a few more trailers.
I am torn between a 10 year old 24 X 8.5 X 7 9900 with new E rated tires, made out of plywood and a 2 year old 20 X 8.5 X 6.5 made out of OSB.
Older is less expensive but a little big for what I need.
Thinking currently.
Ryan W31
Old 04-23-2024, 06:38 PM
Donnie's Avatar
better to have to much room. it will end up being used.
69 SS L78 Chevelle
70 SS 396 Chevelle
The Following User Says Thank You to Donnie For This Useful Post:
Ryan1969Chevelle (04-23-2024)
  #90
Old 04-25-2024, 02:39 AM
Thinking currently.
Ryan W31
