Old 05-03-2018, 04:38 PM
RAII4speed RAII4speed is offline
Default New fuel tank question
My fuel tank in the 1969 Nova SS was leaking so I changed it and now it has a pressure sound when I remove the cap. This did not happen prior. The tanks look the same and I used the original sending unit. Any opinions on why this is happening?
I don't hate the rich, And I don't pitty the poor
Attachments - The Supercar Registry 2018-05-03%2013_45_40_preview_jpeg (640x360).jpg 1969tank (640x360).jpg
Old 05-03-2018, 05:25 PM
It sounds like your new gas tank is not ventilated through the filler neck so a vented gas cap would be required. It is equipped with a special breathing valve so that it can be used on non-ventilated fuel tanks. The valve relieves the pressure that can build up in the gas tank due to expansion especially on hot days.
Old 05-03-2018, 07:25 PM
My gas cap is vented. And the tanks look the same.
Old 05-03-2018, 07:46 PM
m22mike's Avatar
m22mike m22mike is offline
It is normal to see some + pressure with a anti surge cap. It will appear more noticable with little fuel in the tank after driving on warm days.
These caps are not directly vented to atmosphere . If they were you would spill gas with a full tank during take off.
Mike
Old 05-03-2018, 08:24 PM
So today was the first day that the temp hit 90 degrees and the tank is very low on fuel. I will see what happens going forward. If anyone has any other suggestions, Please let me know.
THANKS
Old 05-03-2018, 08:58 PM
L78steve L78steve is offline
Yes vented one way.
Old 05-03-2018, 09:12 PM
mnyenko mnyenko is offline
The gas cap shown works good on an original tank. The reproduction tank likes the 1971 to 74 cap. GM 413755 or recent replacement GT 85 . Solved excessive pressure build up for my application. Earl
Old 05-03-2018, 09:44 PM
You should have repaired the original tank. Radiator repair shops will fix fuel tank leaks. Your red Nova is a all original unrestored car, that's the way you want to keep it... Just my two cents!!
m22mike (05-03-2018)
Old 05-03-2018, 09:59 PM
That is a great idea. I still have the original tank and it was leaking at the filler neck, So most likely reparable. I will send it out and have it repaired. Thanks for your imput.
The new tank does look good under the car.
Old 05-04-2018, 12:50 PM
novadude novadude is offline
My old '70 Nova did the exact same thing with the OEM tank and cap, and I never did figure out why. The tank had no apparent issues with venting, and it didn't cause any performance issues, or tank damage, so I just lived with the "whoosh".
