Older Paint Formulas
I am looking for a someone who is doing the older basecoat paint formulas that are accurate and match the original factory paint. I have tried PPG and Sikkens and we used both of their cameras to match a 1970 GM Code 53 Gold and 69 Cortez Silver. The formulas they came up with were not even close when I did sprayouts. I understand I am doing full paint on the cars but I still want the correct color in all lights, Not just the sun or shop lighting. Any information will greatly appreciated. Thanks....
Mark .
Kentucky Gold 70 SS/RS L78. 81 Z/28 Silver/Silver Int 09 G8/GXP #992 98 Pontiac GTP Daytona Pace Car #605 90 Olds Touring Sedan SUPRCHRGD L32 83 El Camino |
It’s getting harder since they took the lead out and they spend their resources matching current year models. Another problem is the newer colors use mica or synthetic pearls instead of ground up metals. Had some luck using fleet colors or cheaper lines of paint. Another possibility is waterborne paint.
Today's colors are much cleaner, Trying to get the older dirty metallic look is almost impossible with the the toners they are using in todays colors. I have used Glasrurit for the older colors but our Jobber no longer sells that line. I guess I will have to find another BASF jobber in the area and hope they can match the GM code 53.
Thanks .
Sherwin - Willams has a dead on match for Cortez silver in the ultra 7000 series, B7-2591-00 . I have a formula if you need it.
Shaun |
Wanting CORRECT match for 1970 GM SHADOW GRAY....with CORRECT Metallic !!!!!!!!!
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
Paint.
Chuck. I sent you an email as well. If you do not get it, possibly I can help direct you to the paint you need. Brian Cantera 7782459040
I have found that I either have a part scanned or have them mix to formula a half pint -
Then I pour off some and shoot a test... Check under full spectrum light source - Check direct and 45 degree side shift If it matches great... scale up to what you need to shoot the car. IF NO MATCH I take 3 small clean glass jars number 1-3 on the lid - to each I add 50-60 grams of mixed color (EXACT) then add X GRAMS of desired tint etc to the first jar write the amount on the lid. Then spray check that sample. IF it is not right DISCARD- Take next premeasured sample - add less or more of desired pigment/metallic shoot - compare- IF not right - DISCARD NEXT preweighed sample- add less or more - The light copper metallic for the 73 RS Z I am doing now was a SOB I probably mixed 15 samples trying to get it perfect. The last cortez mixed I had mixed to formula then had to add 805J in order to change the side shift on the metallic... If it is a solid I may shoot it first then determine which color in the mix is too distinct, the last WIMBLEDON WHITE MUSTANG had too much OCHRE tint (mustard yellow), had to have it remixed cut way down on it and I added until it was correct. The 1969 GM code 69 CORTEZ is a HIGHLY magnified sample... the actual image size is less than 1/2" x 1/2" the mottle in there is the actual metallic pigments. Second is light copper metallic 1973 GM CODE 60 BEAR TO MATCH (in the axalta DB as alternate mix formula now)
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
Thread Tools | |
Display Modes | |
