I am sure these are the same for all GM A body and derivitives. I have a n extra upper NOS, Not sure about the bushings, will check.
Paul
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
Sounds good
1970 NOS upper a arms came with ball joint installed but no Shaft or bushings. Lowers came with bushings and ball joint installed. I believe Pontiac upper control arms had shafts and bushings as well as ball joint. I know that Framingham MA plant 69's tended to use the Pontiac style upper shafts with the male threaded ends and nut and washer but I've not seen these used on 70 Chevelle or Monte Carlo so I think you will need to put them together with shafts and bushings if you find NOS Chevrolet upper arms.
Chevrolet A-body also used 2 different design lower arms, one for Big Block engined cars (round bushings) and the other used oval shaped bushings for 6 cylinder and all V8 engines besides Big Block in 1970. There were numerous revisions and superceded part numbers for these but original 70 Chevrolet part #s are 3974217 LH upper, 3877062 RH upper, 3931453 LH lower w/396-454 eng. 3931454 RH lower w/396-454 eng. 3967769 LH lower all engines exc. 396-454 and 3967770 RH lower exc. 396-454. Upper shafts were part # 3849412 and bushings were 3711826. Hope this helps Jeff. Chris |
The Following User Says Thank You to Ls6 Ragtop For This Useful Post: | ||
ORIGLS6 (05-30-2017) |
Contact bbbentley on here.James just parted one out.
https://www.yenko.net/forum/member.php?u=53017 |
My parted out hulk was an early car, October, guarantee you, no NOS anything! Lol. It was rough. Does have halo vinyl top trim. Many good parts left. Steering, brakes, trim, dash, wiring, misc. 402 floor shift tilt, high option 70.
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation |
Contact this guy to see what he has there..
https://chicago.craigslist.org/nch/pts/6153590169.html |
Jeff i have some Chevelle A arms let me check and what condition they are in
