Old 10-18-2017, 10:05 PM
6667ss138 6667ss138 is offline
Default 69 Z/28 manual steering box
I am looking for a April to June dated manual Z/28 close ratio steering gear box.
Thank you!
Old 10-19-2017, 11:50 AM
Manual box was the same as a standard non fast ratio, the pitman arm was 1/2" longer for the Z-28, from 5.25 to 5.75 inches. This should make your box search easier.
Paul
Old 10-19-2017, 01:30 PM
Thank you!
Old 10-19-2017, 02:02 PM
jl8z28 jl8z28 is online now
I have one out of a 69 Z28 that I was holding on to its been refinished and rebuild to concourse standards I can check the date but it's not going to be cheep if you are interested
Old 10-19-2017, 04:43 PM
BLACKLS5 BLACKLS5 is offline
What's the casting number on the gear supposed to be? I have a 5679142 with a date of A1759 if that's what you're looking for.
70 Chevelle Cpe L34 M40 75-75 788
70 El Camino L34 M20 28-C 765
Old 10-19-2017, 10:02 PM
I will double check but it sounds to me like the correct casting number and if I am decoding the date correctly it would be the 175th day of 1969 which was June 23rd. That would be perfect for my 07A car. Can someone please confirm if I have decoded this correctly? If it is correct for my car I will PM you for a price. I do have a correct Z/28 pitman arm that I've had for years so this would fix me up.
Thank you!
Old 10-19-2017, 10:04 PM
Yes, please check your date. I will be doing a concourse restoration on my 69 Z, so I am interested. Thank you!
Old 10-19-2017, 11:15 PM
luv2sixty9 luv2sixty9 is online now
6667ss138,
The box BLACKLS5 has is the correct one.....If your happy with that date, which is also correct like you indicated then go for it. Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 10-19-2017, 11:20 PM
Originally Posted by luv2sixty9 View Post
6667ss138,
Thank you, Dave!
Old 10-19-2017, 11:56 PM
I checked the date on mine and it is 332 of 68
