Re: Removing undercoating
https://www.yenko.net/ubbthreads/ubbt...e_undercoating
The Peelaway stuff is supposed to be pretty effective. I was designed for removal linoleum tile adhesive originally. |
I used kerosene with a plastic scraper and I did not have any scratches and it does not remove the original finish.
Rather than using any kind of chemical, I've had great results with a heat gun and a plastic scraper. Safer.
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] |
Mineral spirits, lots of soaking and it will usually scrape off with a plastic scraper. Messy job but uncovering the usually mint floor pans is worth it.
Thanks for replying
Maybe I will try a couple ways suggested and see what works best... I have a lot of work ahead of me, underside, interior floor pans and so on... |
A small propane torch and a plastic scraper.
Looking for the next project. |
If you're going to use a torch make sure you do that prior to the chemicals or kerosene ... we don't want to read about you in the paper
I like cars more than I like people ..... |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Craig_Maiorana</div><div class="ubbcode-body">If you're going to use a torch make sure you do that prior to the chemicals or kerosene ... we don't want to read about you in the paper
</div></div> Good point! |
I remember reading somewhere(years back)
about using transmission fluid to remove undercoating? If I remeber it was suppose to work well? Any thoughts or experience with trans fluid? |
