Old 06-13-2017, 02:53 PM
BillD BillD is offline
Originally Posted by mockingbird812 View Post
Which manufacturer did you buy Bill?
I don't remember who the manufacturer was. I am sorry I can't be more helpful. Although the wheel pictured in this thread appears to have the oversize center hole.
1966 Chevelle SS396 LS6 M22
Old 06-13-2017, 02:55 PM
day2killa day2killa is offline
thanks again
Old 06-21-2017, 05:25 PM
novadude novadude is offline
The Wheel Vintiques series 62 wheel definitely has the oversize center hole.
You should be able to find plenty of GM OE 15x7 wheels w/ 4.25 backspace if you are patient, as they came on 70s monte carlos and also 77-90 Caprices with the optional suspension (F41?). I have one spare from a ~73-74 Monte Carlo, but one wheel won't do you much good.
Old 06-22-2017, 11:52 AM
Wheel Vintiques are lug-centric wheels and many have had vibration issues using them because they are never truly centered. I was told that Ricks or Year One has some repro wheels that are hub-centric and believe Newstagia Wheel also reps a line with hub-centric rims. Might be worth looking into or you could have some balancing issues and vibration.
Original rims would obviously be hub-centric but I'd have them trued up if running slicks. Hope that helps.
Old 06-23-2017, 01:14 PM
rat tuned rat tuned is offline
years ago I ran stock 15-8 corvette rallies with a set of 28"tall by 12" wide M&h racemasters. my outer lips are rolled. but they fit easily.
Old 06-23-2017, 05:14 PM
Yes 15X8 rallys or 15X7 rally's work fine!
