Old 03-08-2021, 12:06 AM
Pro Stock John's Avatar
Pro Stock John Pro Stock John is online now
Super Moderator
Default ID'g a 1968 Z/28
Have a local friend with what might be a 1968 Z/28. He's owned a bunch of Camaros over the years, older, so not necessarily his first rodeo.
15" tire sticker in glove box, has a 12 bolt in there. Are there any codes that might be on suspension parts to help him?
Orig engine and trans are gone.
Old 03-08-2021, 12:10 AM
scuncio scuncio is offline
I would say look for a BU, BV, BO or BW rear - that covers most of the usual Z ratios. Also, check for disc brakes and a speedometer cable exiting the firewall near the distributor.
Old 03-08-2021, 12:12 AM
Also - check for evidence of rear bumper guards, 6000rpm tach if so equipped, and a three row radiator with “UH” code.
Old 03-08-2021, 12:17 AM
Stefano Stefano is offline
Yes, the small block spring tags will be different than big blocks if they are still there / visible. While the 15" tire sticker is a good clue I have seen non Z28s with that sticker.
Also, I have found remnants of the white / black stripe paint on top of the original paint under the wiper cowl.
Old 03-08-2021, 12:21 AM
napa68 napa68 is online now
I have a 48k mile 68 in my possession right now that is relatively unrestored. If you like pics or have questions, just PM me.
Tim
Old 03-08-2021, 12:29 AM
Super Moderator
Sent the owner a link to the thread, thanks for the comments guys.
Old 03-08-2021, 01:20 AM
fiveforty fiveforty is offline
Spring sticker
Old 03-08-2021, 01:28 AM
If it has production line dated fenders that have only been drilled once for the Z28 emblem. This is an 04D car with fenders dated the 11th and 15th week of 1968
Old 03-08-2021, 03:12 AM
Z/28 has 4 leaf at rear. Y55 battery original so look for signs the negative wire off the negative battery cable was grounded to radiator support since it had reverse polarity.
Many times an engine is changed other original parts remained so check alternator, carb, etc.... power booster and disc brakes up front?
68,69&2015 Z/28's
Few Corvettes
Old 03-09-2021, 02:19 AM
Kurt S Kurt S is offline
Complete list: http://www.camaros.org/diffs68.shtml
Kurt S - CRG
The Following User Says Thank You to Kurt S For This Useful Post:
lbnaz (03-09-2021)
