427 396 402 blocks and misc rare parts selling all one shot lowered price
For sale is a ton of rare 60's and 70's chevy muscle car parts
Here is a list of what I have 1- 3963512.... ce. I 18 9....4 bolt 427 $4500 2- 3955270 no pad numbers standard deck height checked with etch H 23 8 2 bolt 427 $4500 3- 3969854.. t10070ctx.. j 20 8 2 bolt 402 $500 4-3916321... ti024ir... i 18 7 4bolt 427 68 corvette vin $5000 5-3999290.. ce .... c 15 73..... 2 bolt 402 $500 6- 3869942 no stamp also etched and no numbers found.. J 18 6 4 bolt 427.. $5500 7- 3855961.. ef ... e 13 6... 2bolt 396 $3500 8- 3855961.. to33ie.. c 15 6.. 2 bolt 396 425hp $4500 9- 3916321.. to9i3ij.. i 2 7... 2 bolt 427 $5000 Also 7115 crankshaft needs to be cut. $500 Almost new set of original l88 pistons $450 N.o.s set of l88 pistons with nos rings and wrist pins. Rare!! $2100 492 small block heads $300 Nos in original box NMW torque lift ladder traction bars for gm intermediate coil spring cars chevelle ect... N.o.s 61 corvette dash housing $1100 61 corvette ram horn exhaust manifolds $300 pr Zl1 fuel pump $350 69 copo 427 camaro fuel pump $400 Crate full of small and big block crank pulleys some n.o.s corvette.. 2 muncie cases $450 each 1 muncie tranny (apart) $800 3 misc big and small block point distrbutors 1 big block rt side exhaust manifold unknown date as shield is still on.. $200 1969 camaro small block fan shroud original $150 Nos set of 8 r45xls Ac delco spark plugs $150 set Ac delco nos 4000 and 5001 guide headlamp bulbs 1 of each $75 each Nos gm guide plates 2 sets $100 set Nos gm head bolts long and short 2 sets 5 alternators all mid 60's need rebuilt 1 starter 61 date and 1 starter housing I forget the date Original corvette caliper cores 3 of them Misc n.o.s ac delco fuel pumps.. about 5 Big block clutch fans Small block clutch fans Misc components from copo smog system 1970 camaro ss steering column and wheel with ss horn ring $250 Crate of small and big block engine brackets. Original big block camaro harrison radiator core good tanks $350 1969 small block 4 barrel intake with original quadrajet. $200 Delco remy raised letter distributor caps 2 used 1 n.o.s 100 each used and 150 for nos 1966 and a 1967 big block water pump $175 each 12 bolt 4 series carrier Corvette 3 and 4 series carriers 1 of each Im sure there is more Looking to sell as a complete lot 25,000 firm Last edited by Parts4race351; 05-24-2017 at 03:03 PM. |
Bump more stuff added
