Old 08-14-2011, 07:16 PM
John Brown's Avatar
John Brown John Brown is online now
Default Re: COPO Chevelle start/run problems
The little yellow wire that runs from the solenoid powers the ignition when the key and switch are in the start position. When you release the key, you would be running on the normal ignition switch and the resistor wire running through the rest of the harness. If the ignition switch or the resistor wire is at fault, it could start or run in the start position, but not in the run position.
John Brown
Old 08-14-2011, 07:46 PM
bwag bwag is offline
When troubleshooting a no run condition , I always start with a test light at the coil + terminal. With the ignition in RUN position there should be 12 Volts at the + terminal . If no voltage there go to the 12 ga purple wire on the Ign switch and test . If you have power there ,find the open between the two places you just tested . If no power at the switch ,adjust the switch first ,if still no power replace the switch.
Old 08-14-2011, 08:29 PM
John Brown's Avatar
Purple wire just energizes the solenoid. It does have to go through the neutral safety switch first though. It doesn't really have anything to do with the actual ignition circuit.
John Brown
Old 08-15-2011, 01:28 AM
napa68 napa68 is offline
The power to the ignition is overrode from the starter solenoid. It then gets full battery voltage as opposed to resisted voltage.
Different circut, thus different results.
Tim
Old 08-16-2011, 01:05 AM
Thanks guys. So, ...... + side of coil had 10 volts in the start position, but 0 volts in the run position. Put a wire from + battery direct to + coil and started right up and ran. Looks like the wiring harness (resister wire) is no good as predicted by you folks. New wiring harness on the way!
Thanks to all the responded!
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 08-16-2011, 01:24 AM
njsteve njsteve is offline
Happy to hear our combined advice worked. Now I can finally tell my wife that someone, somewhere in the universe followed my advice and achieved success.
[img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 08-16-2011, 03:43 PM
SS427's Avatar
SS427 SS427 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">Now I can finally tell my wife that someone, somewhere in the universe followed my advice and achieved success.
[img]<<GRAEMLIN_URL>>/grin.gif[/img] </div></div>
Doesn't that feel good? It has likely happened many times before, you just didn't know it..... [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Rick Nelson
Old 08-16-2011, 03:52 PM
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] Some smart dudes round here........... and alot of been-there-done-that folks too!!!!!!!! [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Old 08-16-2011, 06:15 PM
enio45 enio45 is offline
Excellent - that is why i love this site, so much experience and so ready to help!
Let me renew my membership NOW!!
Eddie M
MBTMF
68 COPO Camaro 9737 non-converted YENKO
69 YENKO SC Camaro, Hugger Orange - born with engine!
Old 08-16-2011, 07:05 PM
[img]<<GRAEMLIN_URL>>/headbang.gif[/img] [img]<<GRAEMLIN_URL>>/headbang.gif[/img] Let's get <span style="font-size: 26pt"><span style="font-weight: bold"><span style="font-style: italic"><span style="color: #FF0000"><span style="text-decoration: underline">FIRED UP</span></span></span></span></span> Eddie!! [img]<<GRAEMLIN_URL>>/headbang.gif[/img] [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
