Old 06-27-2009, 02:38 AM
x  Baldwin  Motion's Avatar
Default Re: Rebuilding a Hurst Shifter
Thanks Mike great encouragement. Is there any hope for my wobbly muncie spaghetti shifter? I have a Hurst in the car now but am hoping to refurbish the original somday, any advice?
Old 06-27-2009, 06:07 AM
m22mike's Avatar
m22mike m22mike is offline
Mount the Muncie on a nice walnut board and tell your frieds you won it at a car show
Old 06-27-2009, 06:10 AM
DarrenX33's Avatar
Thanks Mikey. I'm looking forward to diving in. Once again your fine work is an inspiration for this old sailor.
Maybe we should set up a conference call or Netmeeting while we do this?
Thanks for the info Mike.
1969 Z28
1972 Corvette
Old 06-27-2009, 06:54 AM
DarrenX33's Avatar
How do I remove the pin (or cylinder) that holds everything in place? I am starting to tear it apart and am taking step by step photos to post here..
1969 Z28
1972 Corvette
Old 06-27-2009, 06:58 AM
Good idea Darren. This will be another good reference thread that we can create a "post-it" or whatever its called. I'll betcha lots of guys would look forward to this post. Go for it Darren!!
Old 06-27-2009, 03:02 PM
RPOL88 RPOL88 is offline
Notice in the last pic Mike has posted you can see the end of the pin. Use a large drift and angle it so as to catch the space between the housing and the pin. Don't be afraid to hit it. If you want, send me your address and I will send you a replacement pin. I make them from oil hardened tool steel with a hardness of 54 to 56 RC. No charge. Tom.
Old 06-27-2009, 04:41 PM
DarrenX33's Avatar
Flat blade worked (took about 30 seconds). No hammer necessary, just a little pressure and it pushed out. The rest pulled out by hand. Thanks for the suggestions! I am going to wait to post all my photos when I am done taking it apart so they are all in order so it is easy to read.
1969 Z28
1972 Corvette
Old 06-29-2009, 09:40 PM
m22mike's Avatar
Darren sent me a PM and asked how to take this part of the shifter apart. I will answere here so "Buckeye Boy" Sam don't ax the same question later, pay attention Sam...
Drive out both roll pins ( to be replaced latter )
Then twist the shifter and pull out the large diameter spring.
Pull this gizmo stright out
Once that flat "T" is out, again twist the lever some and pull the small spring out, and watch for the washer. This washer is on the inside.
Good idea to take some notes and/or alot of pictures for reassembly. Pay attention to the position the shifter lever in relation to that "U" shaped spring housing... it can go together backwords...I did it... even with the pictures.
Mike
Old 06-29-2009, 11:28 PM
DarrenX33's Avatar
Hey guys, just found this very nice link. Basically what I was planning on putting together..
http://www.fordmuscle.com/forums/tra...t-shifter.html
1969 Z28
1972 Corvette
Old 06-29-2009, 11:50 PM
Darren - you're not getting off that easy . That dude's Hurst SCP is going on top of a F*#d Top Loader. I need to see one with a Chevy application. (good link)
Mike - pay attention to what ?
