Old 10-16-2017, 02:30 PM
Default '69 Chevelle Master Cylinder.
Did a search for latest go-to facility for master cylinder rebuild and it was a bit dated. Found a leak in mine and running out of time for MCACN!!! So probably best for me to track down a rebuilt one and buy it out right. So, please let me know what you have. 06A built '69 Chevelle.
Thanks!
P.s. Will post under parts wanted too!
Old 10-16-2017, 03:36 PM
VintageMusclecar's Avatar
Sam;
They're not that hard to rebuild if you're willing to tackle it yourself. Rebuild kits are available from RockAuto under both AC Delco and Raybestos product lines.
Old 10-16-2017, 11:00 PM
Default Master cyl
----Assuming that you want a BA dated master. Don't know your dates but there are a few on E-bay. I have been looking ever since I ended up with the COPO for a correct master and finally got lucky right off our favorite website....this one!!! every one on E-bay requires some kind of up-date but its the date that's the problem as always. BA's are tough. You may be able to get yours done in time if you get hold of the guys at Karps in Upland CA. ph.no. is 909-985-0800. Tell them you can jump in front of me because I don't have a time constraint!!! Hope this helps.......Bill S
----They will, of course, sleeve it if necessary!
Old 10-16-2017, 11:53 PM
Wise words from all you alls!!! Thanks for your consideration. My package went out this evening to Whitepost as they have a good rep and good turn around. I'll let you know how this turns out.
For some reason the wife said "just use the emergency brake". Kind of makes me wonder....
