Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 07-07-2017, 12:20 PM
Over Anxious Over Anxious is offline
What a great car and project! Thanks for sharing.
Joe in Detroit
Over Anxious
67 68 69 Camaros on Instagram
Old 07-07-2017, 01:06 PM
cook_dw cook_dw is offline
Banned
Old 07-11-2017, 08:10 PM
1968w427gte 1968w427gte is offline
Great project. Thanks for sharing all the pictures.
Old 07-17-2017, 01:27 PM
Zman1969 Zman1969 is offline
Talking
following along with this build - classic! now about the engine,
I believe this imperfection will hone out just fine
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 07-17-2017, 11:04 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Ha! Yeah....actually, that's all fixed! Sleeves did it! I'll be taking the block back to the machine shop shortly for a boil/bake cleaning, and then start thinking about building a stout stroker in stock clothes! Going to post up more at the end of the month. But I was able to save the original engine, so that's something I'm beyond excited about!
Cheers
Dave
Old 08-03-2017, 11:45 AM
A12pilot's Avatar
Welp....it was a slow going, and fortunately, I didn't have to worry about blasting the floor pans. Here's an action shot in my full "2001 A Space Odyssey" get up! Due to the Hunnit Percent Humditiy here in Houston, the metal was rusting right after I blasted it!
Weight of Dave before blasting: 165lbs. Weight of Dave after blasting: 152lbs. That's a net loss of 13lbs. What'd I lose? Oh, that's common sense as to why I do things like this!!!!! But the results are worth it!!!!! No more rust, no more grime, no more gunk!!!!
I decided to go with the Red Oxide primer look for a number of reasons. Mainly, all the early Mustangs I've seen that had the Red Oxide underneath always looks sharp with the freshly restored contrasting parts against it. Secondly, I checked with the MCA rules, and even though I won't have the car judged, acceptable undercarriage colors for all Mustangs as Red Oxide, Gray, and Black. So there you go! Decision made and now it's done. I'm diggin' it!!!!!!
Cheers
Dave
Old 08-03-2017, 11:49 AM
A12pilot's Avatar
Soooo....as you can see, only the bottom was primed. Now that it's all done and sealed, I'll be taking a pressure washer and blasting the interior, trunk, and engine bay to remove all the dust/trash that's left over after all of this. Also, I'll remove the doors, glass, and fenders. Once that's done I can blast the engine bay, trunk and parts of the interior. Once clean I'll epoxy prime those areas. More to come with hopefully the rest of the car primed up this week!!!!
A nice improvement from what I started with!
Cheers
Dave
Old 08-03-2017, 11:53 AM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Nice! Like you said, that red oxide will look great when assembled. I did the same thing on my 69 interior and I love the results.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 08-07-2017, 12:00 PM
A12pilot's Avatar
Progress, progress! Luckily, everyone at the shop was out of town for the weekend so I was able to get the exterior of the car completely stripped and primed without anyone stopping in to ask for help or chat about things I don't want to chat about. .
As you can see for ease of sanding, I left the car assembled. The next phase will be to remove the fenders and doors, then get out the pressure washer and let 3000psi of water pressure coming out of the Turbo 5100 rotary nozzle remove the remaining trash/dirt and grime in the interior and trunk area. Once that's all done I'll spray the interior redoxide and I'll be into the bodywork!
Stay tuned for more...block..block...sand...sand....
Cheers
Dave
Old 08-07-2017, 12:03 PM
A12pilot's Avatar
Paint next week! Well.....maybe that's a tish on the optimistic side
Cheers
