Old 01-17-2017, 06:11 AM
Default Re: 68 Camaro multiplex
It looks very nice. Well done.
Jason
Old 01-19-2017, 03:03 PM
tuty tuty is offline
jason is there anyway you can tell me if the top of the label is 31/4 and the bottom of label is 31/8 or something like that i just noticed its smaller on the bottom than top by the distance the buttons to edge bottom looks closer than top
thx
Old 01-19-2017, 03:42 PM
I will not be near that storage for a couple days but I can check when I am near it. I would be surprised if it is narrower at the bottom.
Jason
Old 01-26-2017, 03:03 PM
Hi jason since yours original maybe when you get a chance you could check to see if top is around 31/8 and bottom is around 3
thx
Old 02-11-2017, 07:16 PM
scuncio scuncio is offline
Here is a neat '68 RS/SS with the original multiplex intact. This guy may be able to answer your question.
1968 Camaro RS/SS
Old 02-15-2017, 12:17 PM
Wow what a beauty is this car restored or original it looks like it has every available option including
the big block. Lucky guy! Hey jason you think he would take the console door off and give me dimensions
that I need in between first place car shows LOL.It seems the car doesnt get driven to often not a crease or smudge or piece of lint or dirt anywhere. Again WOW what a beauty.
Old 02-15-2017, 12:21 PM
Oops small block
Old 08-29-2017, 03:52 AM
fsc66 fsc66 is offline
Default Multiplex Reproduction Decal
Finally finished reproducing the multiplex decals, have them listed on ebay if anyone is interested.
http://www.ebay.com/itm/253121303779...84.m1555.l2649
or you can just PM me if you'd prefer.
Notes:
Exact reproduction of the original multiplex decal with the exception that this decal does not have slightly raised lettering. Correct trapezoidal shape, correct measurements, correct punched holes, correct text alignment to holes and correct foil material. Created by a sign shop that manufactures decals for exterior use. Adhesive used for these decals is far superior to original and the same adhesive used for exterior use. This should prevent the edge curling issue that occurs with the original decals.
Limited quantity so please order as soon as possible
Paul
[email protected]
