Old 12-05-2014, 01:09 PM
micky69396 micky69396 is offline
Default Re: Big Block Exhaust Manifold gaskets
no gaskets, I have used the copper before and high temp red as well. Gaskets were in trucks.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 12-05-2014, 01:16 PM
earntaz earntaz is offline
If you're a 100% certain the head and manifold surfaces are flat, no gasket will be required. If there is a question if this is true, then what Al said is what you need to do ... use the sealer.
TAZ
Old 12-05-2014, 03:38 PM
70 copo 70 copo is offline
If you have manifolds that are not warped I just use the white paste. Any parts store 3 dollars and a pinch does the trick for each side.
Old 12-05-2014, 06:46 PM
Dicky's Avatar
Dicky Dicky is offline
I've always used Ultra Copper on my aluminum headed
drag race engines with no problems or leaks that could be seen.
Although the headers are not cast iron nor the heads it certainly
is a much easier assembly.
Dicky [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Dicky
