#11
Re: Hot-running LS6
190 to 210 isn't unusual for these cars. If I recall correctly the OE thermostats were in the 185-195 range. I replaced mine early-on to bring the temp down.
We attended the Street Machine Nat'ls the year it was held at Gateway in E. St. Louis and were trapped in the gridlock trying to leave on Saturday afternoon. My battery wasn't doing well and I was afraid the car might not restart so we let it idle for over three hours. The car never once got above 165. That was with Turbo Blue in the tank and timing at 2 degrees advance. Yes, timing can be a factor. Another thing to check out is your water pump. I have a friend who built an L-88 for his '69 Chevelle and had similar trouble. He installed a new four core radiator but still no help. Finally tore into the water pump and found the fins on the impeller were about half the size of the ones on the other pumps he had used. Changed pumps and the problem was fixed. Just some thoughts. [img]/ubbthreads/images/graemlins/dunno.gif[/img] Dennis
Don't mistake education for intelligence. I worked with educated people. I socialize with intelligent people. |
#12
Re: Hot-running LS6
Interesting responses with some good tips. Sounds like MOST folks are saying that "these cars run between 190 and 210 (and up)" so that performance shouldn't be shocking. However there are things one can do to chip away at the cooling system performance. I appreciate the tips and hope to see more; I'm sure we could all learn a thing or to about the "norm" of these cars. I have owned an SS396 for years but am new to the LS6, so I don't yet have a "vibe" for the "norm" for the car. [img]/ubbthreads/images/graemlins/confused.gif[/img] I'm getting there though...
https://picasaweb.google.com/1070244...e?noredirect=1 |
#13
Re: Hot-running LS6
Lots of good answers on the topic at hand. Thermostat, good system check, and timing check should all be on order. Timing plays a big factor, but if it starts/runs well, then you should be close. And, the range you describe is normal for these cars. Heck, that's actually a little cooler than where some of the newer cars run. One thing that is easily overlooked, though, is "pressure". Any idea what radiator cap is on it?
Care for some food for thought...? Low coolant temperatures DO NOT necassarily indicate a well functioning coolant system. If there is no heat transfer between the metal and coolant, then you've got the low coolant temp you're looking for, but you're engine's temp is actually higher. If there is heat in your coolant, then it's doing it's job. Something else that is of help is to get an infrared temp gun and check and see what the engine's temp is actually at, versus what the coolant temp is. If the coolant isn't taking the heat away, but is giving you a low guage reading, then that's really just a fasle sense of security... |
#14
Re: Hot-running LS6
Our '69 L78 4:10 geared Chevelle runs in the 205 range on the highway in hot weather. You are running a lot of rpm at 60 mph. The temperature will stay below 200 at idle. Never had a problem in 21K miles. Total timing will make some difference.
Chevelleless after 46 years......but we did find a low mileage, six speed, silver 2005 Corvette. It will just have to do for now. |
#15
Re: Hot-running LS6
Lots of good answers on the topic at hand. Thermostat, good system check, and timing check should all be on order. Timing plays a big factor, but if it starts/runs well, then you should be close. And, the range you describe is normal for these cars. Heck, that's actually a little cooler than where some of the newer cars run. One thing that is easily overlooked, though, is "pressure". Any idea what radiator cap is on it? [/ QUOTE ] <font color="blue"> Great tips Rob. Everyone has had something good to add, and if you add up all the responses, there is a great body of knowledge on supercar cooling systems here. As far as the radiator cap, it is a repop of the original GM cap from Ground Up Restorations. </font>
#16
Re: Hot-running LS6
Things that help:
good radiator cap.....for every 1 lb pressure the boiling temp raise is aprox. 2 degrees. 16 lb cap working properly will raise boiling point to aprox. 244 degrees. Car operating at 200 is still 44 degrees below boiling point. Antifreeze/antiboil raises this boiling point also. Higher octane fuel makes alot of difference...not sure how much but the difference between 96 pump and 110 race fuel is tremendous. Less timing lowers operating temp but also hurts performance..there is a happy medium Things that hurt: Low pressure or leaking radiator cap. Weak antifreeze Low octane fuel Lean fuel condition Too much timing I have seen alot of times that someone will take a thermostat out of a car and it run hotter....so in saying that...if the flow of water is too fast it doesn't have time to cool properly, but on the same hand if it is too slow it won't either. Use one of the new Clutch fan should not affect any driving speeds over 40 mph or so. And last but not least.....DON'T TRUST YOUR GAUGE....either check temp with a thermo gun or an old fashioned thermoter in the rad. Hope some of this helps.
20 foot 75 hp good time at the lake |
#17
Re: Hot-running LS6
------Us guys with big block Corvettes have suffered forever with different over-heating issues.All of the above mentioned are important.The infrared gun will really help you out.Shoot it somewhere near the sending unit and then check against the guage.The sending units sold today and even old ones are calibrated differently than the original one that came in your engine.You may be actually running cooler than you think.If you find this to be true get a Corvette Central catalog(or www.corvettecentral.com).In there somewhere you will find a little infinetly adjustable inline electrical "dohickey" (technical enough for you?) that,once installed,you can adjust the guage reading to read correctly.It doesnt cost too much and will keep your guage reading correctly forever.Hope this helps as it is a real slick little unit..............Bill S
#18
Re: Hot-running LS6
190 on the hiway seems reasonable, but over 210,and you do not hear the fan clutch start locking in and pull the temp back down... i would be looking for a restricted radiator.if the radiator is not dumping heat off to the fan coil then the fan is not going to engage,if the radiator is plugged it wont transfer heat.another thing to watch closely is these systems get alot of air pockets in them whenever the cooling system has been worked on or drained, it is important to work the air out while the engine is idling and the t-stat is open, by pinching off the upper radiator hose on and off for a few minutes, this will help purge the air out of the system [img]/ubbthreads/images/graemlins/beers.gif[/img]
#19
Re: Hot-running LS6
All of the above mentioned items are necessary for a cooler running engine, but some more things are necessary for everything to work properly. Make sure all of your shrouds are in place. Your fan shroud and fan position in the shoud is important. You need to have about half of your fan outside of the shroud so that it is pulling the air through and not just swirling inside. Also, the attachment under the radiator that protruds out. I have found that if I run my car over a certain speed without that piece in, the temp rises quickly. The air is searching for the path of least resistance and sometimes it will go under the car instead of through the radiator where the water can be cooled.
A clean radiator and block, proper functioning water pump and fan clutch, properly positioned shrouds, and a good flowing thermostat (Robert Shaw) will make any system work as intended. Another piece of advice. Whenever you flush or change out your coolant, add back in a can of waterpump lubricant/anti-rust. This is one thing that is added at the factory, but is lacking in all antifreeze mixtures. Helps to keep all of the cooling system operating properly for a long time to come! [img]/ubbthreads/images/graemlins/naughty.gif[/img]
Snarl softly and carry a big stick! 1969 Hurst/Olds 13.26 @ 103.12 Pure Stock Rusty Small |
