Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 08-10-2017, 04:08 PM
wannarun70 wannarun70 is offline
Default Messages
My sent messages are not showing up in my sent box. Have about 132 total messages saved. Any help appreciated. Thanks. Mark
Old 08-10-2017, 04:23 PM
Jody to the rescue
Old 08-10-2017, 05:09 PM
In your User CP, are you for sure clicking on 'Private Messages' then 'Sent Items' when it pops up?
Old 08-10-2017, 05:38 PM
The person is getting the message. It's just not showing in my message sent folder.
Old 08-10-2017, 05:47 PM
Gotcha but just thought I'd ask as I was having the same problem then found my sent messages were indeed there.
Again, try clicking on User CP then in the left column go down to and click on 'Private Messages' then again on 'Sent Items' when it pops up.
Good luck!
wannarun70 (08-10-2017)
Old 08-10-2017, 07:13 PM
camcojb's Avatar
camcojb camcojb is offline
Administrator
Good luck!
Pete is correct. Also can go user cp/edit options/ . Scroll down to the bottom of the private message box and you'll see this:
Save a copy of sent messages in my Sent Items folder by default
Make sure the box is clicked. I changed yours, they should show up now.
Jody
Old 08-10-2017, 07:23 PM
Thanks Pete and Jody
Old 08-10-2017, 07:25 PM
Thanks Jody and checking the Save Sent Items box was exacly where Wannarun and I were just at w/ PM's.
Here's another query for you;
You used to be able to view all User Posts back to their very first one, now only 25 or so seem available?
When looking for old postings, searching User Posts was often the easy way to find them...including searching my own old posts too.
Any chance you can bring back the higher quantity thing?
Thanks!
Old 08-10-2017, 09:11 PM
camcojb's Avatar
Administrator
Thanks!
I just logged in as a paid member and clicked on your username. Clicked statistics, then find all posts by you and it lists the last 500 posts you made. Usually that's enough, can really bog a site down if you allow it to go back to all posts by all members.
Jody
Old 08-23-2017, 06:33 PM
fastco fastco is offline
I am also having a problems seeing my sent messages. I went to the CP and made sure the box to display sent messages was checked off and did so. I still only see my older sent messages, not the ones sent in the last couple of days, any help is appreciated.
paul
