Old 04-06-2018, 04:51 PM
Will a 1502 fit a 396 block?
Old 04-06-2018, 08:24 PM
John Brown's Avatar
I believe the 1502 didn't have provisions for the 55-57 bellhousing mounts, but still had provisions for a bolt to the bellhousing starter. So yes, it should work, as long as you use the small snout cast iron starter used on stick shift 396, 427, and 454. Aluminum snout starter wouldn't normally fit, unless you cut one it down on a lathe like I did to lighten the starter my 57 Chevy. Been there, done that. Don't suggest it cause it will weaken the casting severely.
John Brown
mockingbird812 (04-06-2018)
  #13
Old 04-06-2018, 08:32 PM
John Brown's Avatar
One other item that might be of interest, 1957 thru 1961 Turboglide starters bolted to the block and mated up to a 168 tooth flywheel.
John Brown
Old 04-06-2018, 11:53 PM
Thanks John. Here is another vintage ad for a ‘67 Lakewood shield.
Old 04-29-2018, 10:11 PM
Bernhard Bernhard is offline
I just picked up the correct bell housing for my build off ebay
So I just wanted to thank everyone again.
https://www.ebay.com/itm/12310173820...&s=ci&mail=sys
69 442 post bench 3 pedal
Old 08-27-2018, 01:05 AM
wheelhop wheelhop is offline
Any thoughts on this bellhousing? guys says it's a Lakewood from the early to mid eighties and had it on his 67 big block chevelle.
Old 08-27-2018, 01:06 AM
Were Lakewoods made in Mexico?
Old 08-28-2018, 01:50 AM
I primed, painted and cleared the scattershield and block plate.
Old 08-28-2018, 02:11 AM
Wasn't the plate black?
Old 08-28-2018, 02:16 AM
It was rusty & orange when I bought it and no evidence of black underneath
