#11
X2 -- don't do something you will regret in the future ... slide it under the bench!! TAZ
#12
Everything I own is Rat-powered so I'm a hardcore fan of the BBC. But that said, they are heavy pigs especially when iron-headed and will really shove the nose of the car down. I kinda like the idea of a 427 SBC disguised to look like a stock 302: orange paint, finned valve covers, stock aluminum intake, etc.
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
#13
If you change the car to a big block you'll have other costs... Heater core, heater core cover, motor mounts, motor mount stands, headers, modifying exhaust, bellhousing (likely), trans cross member, etc. If you want to keep the build a tad more manageable, you could run a 427 small block or even a 383 stroker. GM Performance Parts as a great 383 stroker that makes good power.
Follow me on Instagram: https://www.instagram.com/mbcgarage/ |
#14
Just rebuild the 302 with some better upgrades. Change the trans and also go with a little lower rear gear. Will run and perform very well. Why go thru all that BB swap and push that 302 motor under the bench just to rust up?
#15
Thanks for the opinions and advice. That little 302 just doesn't have the torque for what I want to do with it. Something like a 383 or 406 (a SB 427 would be awesome but out of the budget) should give me what I need.
I'm going to get the 302 down to a short block and put it up for sale. LOL, anyone interested?
1968 Camaro Ex-ISCA Show Car John 10:30 |
#16
Does the 302 still have the VIN for your car stamped into the side of the block? If it does then you need to keep it with the car. Even though the block has been decked the VIN will still identify it as a 302 if it matches your true Z28.
#17
You can make some pretty obnoxious torque with a garden variety 400 small block, even with factory heads. Built right, these make for stupid--and cheap-- fun on the street.
For whatever reason they seem to have somewhat fallen out of favor, so the prices for a decent core are down. If you choose to go that route, be mindful that they are known for cracks so make sure you're starting with a good core. Also, the 2 bolt blocks are actually stronger than the 4 bolts in stock form. If you plan on really stepping on it, it doesn't cost much to convert the center 3 mains on a 2 bolt block to splayed caps. Quote:
#18
Freddie, the engine isn't original to the car, so there's no intrinsic value of keeping it with my car. I'd love to find the original Z but the chances of that are pretty slim. I'm going to pull the engine over the next couple weeks once I get some house stuff done and will look for that VIN on the side. I'm all for a large displacement small block.
#19
House stuff. That's very close to me right now. I've got the inside of my house pretty much torn apart right now and the Camaro is sitting in the shop waiting for me to get it ready for SCR21.
The Following User Says Thank You to big gear head For This Useful Post: | ||
markinnaples (04-11-2018) |
#20
I run a 70 LT-1 spec engine in my Z. Standard bore. Factory LT-1 pistons, factory 2.02 heads (186) with no porting, Federal Mogul copy of the 178 camshaft, wide ratio muncie, 4:10 rear gear, frame connectors, traction bars (SSM Lift bars) and 255 60 15 BG Goodrich tires. Didn't even grind the valves or put valve guies in these old used heads, so it smokes a bit.
I can smoke the tires all the way to redline in the first three gears even with SF connectors and traction bars. What would I do with more torque? I have all the pieces here (set up Eric helped me put together) that include RacTec pistons, fully ported heads, port matched high rise, more aggressive cam, etc. I have never put it together because, even though it will probably produce about 100 more hp than what I have, I don't know that I can take advantage of the extra power without figuring out how to get bettter traction. For a street car, it is plenty fun. If I was willing to put slicks on it and risk carnage, perhaps I could make it "drag strip" faster. I really don't care to to that. Will it keep up with modern high performance cars? Not a chance. No traction control. No way it could keep up with Sherri's CL600 (V12 twin turbo laying down 543 HP and even more torque). Yes, you can build a first gen Camaro that will run with the CL600, but not cheaply. My 02 cents: if it isn't going to be a race car, don't build a race car. Without huge rear meats, your not putting much of that torque down anyway. Find a good forged 350 crank, use a good set of heads (if it were me, I would go AFR) and get a good camshaft rec from Eric, small tube headers, and go have some fun.
The Following 2 Users Say Thank You to Lynn For This Useful Post: | ||
markinnaples (04-11-2018), VintageMusclecar (04-11-2018) |
Thread Tools | |
Display Modes | |
