Old 06-16-2017, 06:14 PM
Default 3964290 Big Block Chevy Cylinder Heads 1970 Oval Port FRESH
This is a fresh pair of 3964290 cylinder heads for a Big Block Chevy engine. These were used on 1970 oval port applications. One is dated J 11 9 and the other is dated C 4 70.
These heads are freshly built and have not been used since being completely gone through. They were bolted on an engine and removed before the engine was ever started. The heads have all new guides, hardened seats throughout, positive style valve seals, new stainless valves, new springs, Manley guide plates, and new rockers. The exhaust ports have some surface corrosion. I pulled the valves on the chamber that had the most exhaust port corrosion and the seats are still excellent. I will even include the new head bolts.
$800
I also have a nice used set of 3904290 heads dated L 18 9 and L 29 9. They look to be fairly fresh and have hardened exhaust seats. Those are $600.
Thanks,
Jason
Attachments - The Supercar Registry IMG_2576.JPG IMG_2574.JPG IMG_2573.JPG IMG_2572.JPG
Old 06-16-2017, 06:15 PM
More pics:
Old 06-16-2017, 09:45 PM
Here are pictures of the used pair. They look like they could be cleaned up and bolted on. I pulled the valves out of one chamber to confirm what the seats were. The guides seem tight.
Thanks,
Jason
Old 06-16-2017, 09:46 PM
more pics:
Old 06-25-2017, 03:41 AM
ssl78 ssl78 is offline
I tried sending you a message but I do not think they are going out. I am interested in the J228 840 head you had on Ebay if it is still available. John 6303338333
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-25-2017, 05:26 AM
John,
I was on vacation and just got back. I responded to your PM.
Thanks,
Jason
Old 07-03-2017, 04:18 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
On the J 69 and C 70 heads: Are they stock sized valves and were they milled at all? I'm trying to decide whether I should have a set of 290s I have done or buy another set. Thanks.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 07-04-2017, 03:24 AM
They are stock valve sizes. I don't know for sure if they have been surfaced but I can say the deck surface is still very thick.
Jason
