#351
Re: Traction bars
Look at the Traction Action stickers at Jenkins 69 Camaro
#352
Re: Traction bars
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 169indy</div><div class="ubbcode-body">Finally got the Ground Grabbers (Refurbish-Rebuild) finished, not bad for $25 Swap meet (Cores) find, however, tooling, steel, welding, machining, hardware, plating & reproduction stickers later and they are Road ready (still need to get some U bolts made)
Go ANSEN! JIM </div></div> Wow! They look great, sort of what I envisioned when I saw this set for sale in Pa - but they will take a lot of work as well!!! https://philadelphia.craigslist.org/pts/5411527795.html
#353
Re: Traction bars
Going thru stuff collecting dust on shelves. What is the application for the two bars toward the bottom in this photo? Thanks!
Sam... |
#354
Re: Traction bars
Anybody?
Sam... |
#355
Re: Traction bars
They replace the lower control arms on a Chevelle. I've got an article somewhere. Will post tonight if I can locate it.
#356
Re: Traction bars
Ew, I was hoping that was the application! Should just bolt right in after removing the stock LCA, right? Is the ride significantly altered? What is the affect on the suspension? Any pix of it in place? Would appriciate the article Paul - thanks!
Sam... |
#357
Re: Traction bars
#358
Re: Traction bars
Thanks Paul. That pretty much explains things. Wonder how these stack up against the ladder bars in my original photo above? What is the date of the magazine?
I see they mention Monte Carlos in the article, so must be at least late '69 or '70.
Sam... |
#359
Re: Traction bars
It was Chevy Power cira June 1973. Most other ladder bars are attached to the axle tube in a fixed position.
This one's got 2 pivot points. Probably similar but cooler looking to a good boxed lower control arm. Probably need something more to control wheel hop. |
#360
Re: Traction bars
I wouldn't it expect these smaller TBs to be as effective the Ladder bars, but they sure look cool. I think I'll put these in the mix for day-twoing my '69 Chevelle. Thanks again Paul. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam... |
