Old 03-26-2017, 03:22 PM
resto4u resto4u is offline
Default weird date code
strange tag http://www.ebay.com/itm/1967-Chevrol...JY1vUF&vxp=mtr
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 03-26-2017, 08:52 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Whats so weird about it? Its 11C. Unless you are talking about the paint on the tag making the C look like a 6?
If you look closely you can see the raised stamping is clearly a C
Old 03-27-2017, 03:11 AM
sure looks like 116
Old 03-27-2017, 11:10 AM
It does,but it doesn't resemble the other 6's and has a smaller lower case circle as well as a closed upper case,compared to the others.
It's probably the angle or a dimple making it look like a 6,when it's actually a C.
Old 03-27-2017, 12:17 PM
m22mike's Avatar
m22mike m22mike is offline
I see 11C also.
Mike
Old 03-27-2017, 03:46 PM
Kurt S Kurt S is offline
And the VIN, 124377N133614, matches the 11C build date.
Interesting car: bench seat, column auto shift, RS/SS.
Kurt S - CRG
Old 03-28-2017, 07:56 PM
427TJ's Avatar
427TJ 427TJ is offline
Wire wheelcovers! Dare to be different!
