Old 10-20-2017, 01:27 PM
jasonL78 jasonL78 is offline
I now have all the body panels in primer. The rubber nose will need another coat of primer. The first round of blocking should start next week.
Looking for the next project.
Old 10-20-2017, 02:56 PM
Ryan1969Chevelle's Avatar
Your quality or work and progress rate is outrageous!!
Ryan
Old 10-21-2017, 02:42 AM
daverd daverd is offline
Wow !! What a Fantastic job on the bodywork!!
2013 Silverado
2017 impala
1970 Raylle 350 post coupe
1971 442 W 30 holiday coupe
Old 10-21-2017, 12:02 PM
I love how nice and crisp you go the lines of the car; excellent work.
Old 10-21-2017, 03:19 PM
Crush Crush is online now
Curious as to how many hours it took to get it that straight?
Old 10-22-2017, 10:26 PM
Thank you for all the comments. It's really a labor of love. For me the more I do it the easier it seems. Each fender has about 8 hours of rework. The fender edge along the door needed to be reformed. I drilled out all the spot welds releaf cut the edges and pulled it out to match the door radious. Clamp and reweld. The front lip that comes to the nose was welded wrong to high and to wide. I had to drill the spot welds out and pull the fender down and in then reweld. You would think for a 400 dollar repop fender you wouldn't have to rework it but you do. I use a ruler straight edge on end to make sure all the panels line up. Lots of blocking but the end result speaks for itself.
Old 10-22-2017, 10:31 PM
Yes it does.
Old 11-19-2017, 08:39 PM
First round of blocking the car completed. Now the tedious task of masking everything off. This is the second coat of high build.
Old 11-28-2017, 07:09 PM
May have a color picked out for the GTO Heaven Blue
Old 12-02-2017, 05:34 AM
KingKoser06's Avatar
KingKoser06 KingKoser06 is offline
Hey Jason, I am really loving this build. How much outsourcing do you do with your projects? Do you have another shop do your paint work?
Alex
Alex K
"I was cruising in my stingray late one night, when an XKE pulled up on the right..."
1956 Thunderbird
1964 Corvette
1964 Cadillac DeVille Conv.
2005 Mustang GT
2013 Charger RT
