Old 02-11-2016, 08:34 PM
DW31S's Avatar
DW31S DW31S is offline
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
Ryan, I sent you pictures via text.
Old 02-11-2016, 09:36 PM
Ryan1969Chevelle's Avatar
That is the perfect part Dave!!
Many thanks for keeping my restoration on your radar!!
Now I will need to get moving so I can officially require a DSL at 13.99...........
Ryan
Old 02-11-2016, 09:54 PM
daverd daverd is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">I would think the flywheel was resurfaced already, then never used, from what I see.
Probably just clean off the surface rust. </div></div>x2
The bearing is better in my experience
Take the snap ring out the the bearing
Get the number off of the bearing
Hopefully you can get a replacement....
2013 Silverado
2017 impala
1970 Raylle 350 post coupe
1971 442 W 30 holiday coupe
Old 02-11-2016, 10:22 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: daverd</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">I would think the flywheel was resurfaced already, then never used, from what I see.
Hopefully you can get a replacement.... </div></div>
I will look into this, what is a positive of the bearing lower friction, longer lasting, able to handle more radial force?
Ryan
Old 02-12-2016, 01:07 AM
Funny story: I received the quote to media blast and powder coat my frame, suspension pieces and one set of rims, one set of rims just blast and prime.
Although I am confident the facility would have done a great job the cost was not within my budget.
Again looking for a media blaster/powder coater semi close to me:-)
Ryan
Old 02-12-2016, 01:27 AM
The Dude The Dude is offline
Why does everything have to be powder coated?
Old 02-12-2016, 02:22 AM
Have the frame blasted and blast all the small stuff yourself. Then paint everything.
Old 02-12-2016, 11:30 AM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Checked into the driveshaft loop place I had picked out and they no longer make or sell them:-(
Looking for the bolt on type as inconspicuous as possible:-)
Ryan </div></div>
I may have one of those bolt-on units here, but will have to check.
Took it off a car a few years back, and don't remember if I sold it or not.
If I find it, I'll get it to you. </div></div>
Sorry Ryan, I apparently sold that bolt-on loop along with some other performance stuff awhile back, just didn't remember specifically.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 02-12-2016, 01:42 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Checked into the driveshaft loop place I had picked out and they no longer make or sell them:-(
Ryan </div></div>
Sorry Ryan, I apparently sold that bolt-on loop along with some other performance stuff awhile back, just didn't remember specifically. </div></div>
All good, thanks for looking, Dave hooked me up:-)
Ryan
Old 02-12-2016, 01:45 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: The Dude</div><div class="ubbcode-body">Have the frame blasted and blast all the small stuff yourself. Then paint everything. </div></div>
I am focusing on long term reliability, I plan to hand the car down from one generation to the next. I don't want my grandkids to have to take the car apart and re-restore it, unless they want to of course.
Power coat is better than paint.
Ryan
