Old 05-23-2013, 01:59 AM
Motion Camaro Motion Camaro is offline
Default 1968 Baldwin Motion Camaro Pro Street
I'm in that mood again. Times are tough, work days are long, no time left.
1968 Baldwin Motion Camaro Pro-Street car.
26,000 original miles
This has a full mild steel, round tube chassis with a 90% factory steel body.
Body was a full rotissere, has fresh black paint, chassis is custom painted Viper Metalic Blue Pearl.
There is a narrowed 9" with a Strange 5.14 Center Section, 35 spline spool & Moser 35 Spline Axles with 5/8 studs.
Rear housing is powder coated silver. Pro 4 Link all ceramic coated. Double adjustable Strange Aluminum Coil Over Shocks.
All brackets are coated or painted with stainless hardware.
Wilwood 4 piston rear disc brakes.
15" x 15" Holeshot Wheels with 22 x 33 M/T S/R Radial tires.
12 gallon funny car fuel cell, custom mounted & plumbed.
Full Aeromotive Fuel System with Pro Series Pump & Regulator. Steel braided #12 from pump to engine. #10 return to tank.
Optima Blue Top Battery custom mounted in trunk with Moroso Battery Cable & Moroso Shut-Off Switch with handle.
Custom powder coated tin work with rear belly pan and all hidden fastners.
Nitrous 10lb Bottle mount in trunk with blow off.
Simpson 10' Chute with custom mount.
Fiberglass trunk lid, custom hinges & Pro Wing with struts.
Original rear bumper (rechromed), Original taillamps with LED upgrade.
Corbeau race seats, Wilwood compsite pedals with composite cylinders.
Custom Carbon Dash Panels with Custom Autometer Carbon Fiber Gauges.
Original Door glass with Power window kits.
Custom C6 Corvette style door handles
Removable aluminum trans. tunnel & steel front floors. also: panel over rear end.
American Autowire Body Harness.
Strange Double Adjustable Front Struts with 4 piston brakes.
4" HoleShot Wheels with M/T 7.5x26 S/R Radial front tires.
Manual Steering Rack with custom mounts, column & wheel.
Original front fenders, valence, cowl, grille, radiator support & bumper.
Custom hand built fiberglass cowl hood with billet electric hinges.
Custom Motor Plate, Trans Plate, Trans Xmember & Shifter Mount/DriveShaft Loop, all powder coated/painted.
Engine set back, Custom Firewall.
Flex-a-Lite Radiator/Fan assembly & Recovery Tank.
All factory mouldings, all new weatherstrips.
...more misc parts available to buyer.
>> >> Pic & ad link << <<
This is a brand new piece, being sold as a roller, has never been driven.
Roller = No Motor or Trans.
All parts are original or new.
Needs minor assembly for someone to have one of the baddest 68 Camaro's on the street.
Have Original Motion-Baldwin Chevrolet Paperwork.
Serious Inquiries Only - any questions, call 954-290-6528
Mike Fabian
