Attention 1970 nova owners
I have the opportunity to manufacture the turbo 400 trans kickdown switch bracket. This bracket bolts to the firewall. This is a one year only part for nova's with the turbo 400 trans. The bracket will be an exact match, except it will come in bare steel instead of grey phosphate plating. Right now i am just trying to see if there is enough interest to put this part into production. There is expensive tooling that would have to be done to duplicate this bracket. I need to have a minimum order of 20 pcs. or more to make this feasible. This would be a pre-sale/ made to order. The price would be $99 each. So right now i just need feedback from people who would actually purchase this bracket. Thanks,Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue |
Re: Attention 1970 nova owners
Good luck. I finally found my Idle solenoid switch bracket. THese things are harder to find then hens teeth.
Roger, Your work is perfect, in every way. Congrats, hope you clean house. If only other manufactures, would DO the same thing. BBBenny [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Thanks Benny Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite. |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body">I have the opportunity to manufacture the turbo 400 trans kickdown switch bracket. This bracket bolts to the firewall. This is a one year only part for nova's with the turbo 400 trans. The bracket will be an exact match, except it will come in bare steel instead of grey phosphate plating. Right now i am just trying to see if there is enough interest to put this part into production. There is expensive tooling that would have to be done to duplicate this bracket. I need to have a minimum order of 20 pcs. or more to make this feasible. This would be a pre-sale/ made to order. The price would be $99 each. So right now i just need feedback from people who would actually purchase this bracket. Thanks,Roger </div></div>
Are you talking about the bracket that holds the kickdown switch near the gas pedal?? Can you post a photo??? thanks..wilma
yes that is the bracket. it holds the trans kickdown switch.
In the last image -- is the switch mounted on the correct side of the bracket?
Not sure, i removed the switch before i took it in to get a quote to reproduce.
I would be interested in 2 brackets @ $99.00 each.
Switch should be mounted on the other side of the bracket.
