-   Parts/Memorabilia - Wanted (https://www.yenko.net/forum/forumdisplay.php?f=84)
-   -   1969 power steering box wanted (https://www.yenko.net/forum/showthread.php?t=120939)
WorkinProgress 01-20-2013 05:26 PM
1969 power steering box dated 048 9 stamped on top aluminum cover. Want a clean unrestored box with casting number 5691676. Looking for the 048 9 date only. Call 860-806-0347, or email [email protected]
Thanks, Warren
Ngtflyr 01-22-2013 09:17 PM
Re: 1969 power steering box wanted
Close but no cigar.... I have a 023 9 dated PS box
CamarosRus 09-04-2017 08:19 PM
Is the 5691676 casting power steer gear from my 73' Camaro project
same as, same ratio as early Nova, Camaro (68-70??)............ 5691676
As I'm wanting to use the above Nova box on my 73.......Same exterior look !!!!!!!!!!
Original 73' Camaro box main shaft splines damaged in collision
Thanks
Mr70 09-04-2017 08:48 PM
1 Attachment(s)
I'm rebuilding one right now,that the customer has yet to give me the top cover for.Once it & he arrives,I'll ask him.
JKZ27 09-06-2017 01:55 PM
Warren, did you ever find your dated box after almost 5 years?
There appears to be one in my 68.
Steve Shauger 09-09-2017 05:22 PM
I just spoke with Warren, and he's still looking for the dated power steering box.
Mr70 09-09-2017 08:29 PM
No luck here from the gentleman I referenced earlier.
Lynn 09-09-2017 08:35 PM
If you find a box in the right range, with the correct casting number, you can always transfer your aluminum cover to the new box. I have a few here, and will check dates and casting numbers.
JKZ27 09-09-2017 10:03 PM
2 Attachment(s)
Here is the gear I have. Not real pretty though.
CamarosRus 09-09-2017 10:25 PM
I have a box where the alum cover appears to have 14 9 stamped on it.
I need a good box with casting 5691676 that is applicable to
my 73 Camaro project...ANY DATE
Im thinking that I need a 71-76 Camaro box that has 13-16:1 ratio
whatever that means
