-   -   deuce LT1 valve cover restoration (https://www.yenko.net/forum/showthread.php?t=151837)
madden 11-12-2018 06:39 PM
hi
need help please with the correct way to restore my deuce LT1 valve covers
fro cleaning / striping/ and what finish to put on them?
thank you
chris
YENKO DEUCE REGISTRY 11-12-2018 06:44 PM
The factory finish was a 'dull lustre', while the NOS ones from GM are much shinier - if that's a word. I've learned that if you glass bead them they will lose all lustre. Some guys have had them tumbled in various media with mixed results - likely walnut shells or plastic media is best. Finally, Jerry McNeish offers a 're-skinning' service that has been well received. The rest of us simply buy the best original condition ones we can find and rub them out by hand....
big gear head 11-12-2018 07:27 PM
I blasted my thermostat housing with 100 grit sand and then tumbled it in ceramic media and it came out looking like new, or at least I think so.
BCreekDave 11-12-2018 08:13 PM
1 Attachment(s)
Did mine by lightly blasting with low pressure glass beads then 0000 steel wool to put a light shine in the peaks of the fins to put a very light shine on the flat surfaces. Had to do it twice to get it where I wanted. The key is to not rough it too much in the blast cabinet. I used about 40 psi, just enough to pick up the media and stayed about 8 inches away from it. Just enough really to clean the surface and even out the surface.
I then followed up with the satin finish Ever-Brite to seal the pores and make them easy to keep clean.
Attachment 124904
firstgenaddict 11-12-2018 08:14 PM
3 Attachment(s)
I recently cleaned up the valve covers for my 71 LT1. I feel like they look right as far as the finish color etc.
I used organic PH neutral cleaner then used neverdull cotton wadding, however they were not too dirty when I started....
The FIRST PHOTO IS FINISHED
TWO SECOND PHOTOS ARE PRIOR TO CLEANING.
1971ls6 11-12-2018 10:49 PM
Blast them and the steel wool is the best thing I have found other than jerry
madden 11-14-2018 04:20 PM
thx guys
really appreciate the help
regards
chris
McCune 11-14-2018 06:55 PM
1 Attachment(s)
I used some walnut media in my blast cabinet, followed with steel wool. I think I could have used glass bead at low pressure with similar results.
cwc 11-14-2018 11:55 PM
What grit walnut shell?
marxjunk 11-15-2018 01:14 AM
vapor hone..google it..the high end motor cycle guys use it on delicate parts..does amazing things on aluminum parts....has that luster everyone is looking for...
