Old 02-20-2018, 06:41 PM
Do you mean Ralph?
Old 02-20-2018, 06:46 PM
Burd's Avatar
Burd Burd is offline
Bobby K
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-21-2018, 03:30 AM
9999 9999 is offline
Does he have a website?
--Nick
Old 02-21-2018, 01:42 PM
Burd's Avatar
He doesn't. I'll ask Bobby if he wa to me to pm his cell to anyone interested. Last year he had to have Norwood come by to id what years were what, he got a stack of hoods.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-22-2018, 12:11 AM
njsteve njsteve is offline
I test fitted the new hood today with the help of my daughter. The fit is too tight on the driver's side. I'm going to need to pull out the diver's side fender a little so the rear spear of the hood doesn't rub as it passes by during closing. I think there are lot of bolts that need loosening to do that. I tried removing the rear cowl top fender bolt and the loosening the door jamb bolt but the fender didn't budge at all.
markinnaples (02-26-2018)
  #506
Old 02-28-2018, 11:36 AM
jasonL78 jasonL78 is offline
There should be a bolt on the firewall also and you will have to crack or loosen all the bolts on the inner fender to get the fender to move out. Once all the bolts are tightened its now the structure of the front of the car. For now you may be able to put a body shim behind the hood hinge to push it to the pass side if you have room.
Looking for the next project.
Old 02-28-2018, 01:25 PM
Burd's Avatar
Steve, I picked up the washer bezel insert, maybe you can confirm, I thinks it's fir the early cars, it doesn't fit my 78.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-28-2018, 06:07 PM
Thanks. forgot about that bolt. Once that was loosened was able to move the fender over a little bit but of course it then rubs the top of the door edge when it opens. And the hood stills rubs the inner flange of th fender back by the windshield as it passes.
I ordered a set of Goodmark reproduction hinges from rockauto and they should be here this weekend. I have a feeling the 43 year old hinges have a bit too much side-to-side play in them. You can really move the hood laterally quite a ways, when it is articulating.
Old 02-28-2018, 06:08 PM
PM me a photo and I'll see if it looks familiar.
Old 02-28-2018, 10:47 PM
That worked! I put a 1/16th shim between the hinge and fender on both driver's side hinge bolts. The hood now clears the fender now when you open it. I took the old girl out for a run today since it was sunny and 55 degrees. Started right up. Boy this motor can run! And the wide open throttle noise coming out of the shaker is soooooo much louder than the old Formula hood setup.
I just spent an hour getting the solenoids and brackets hooked up inside the shaker. Next thing is to do is get the wiring plugged in and the Turbo 400 kickdown switch installed on the gas pedal bracket under the dash. (the 1971/72 setup employed the Turbo 400 kickdown switch as the on/off power supply to the shaker solenoid. Very ingenious of the engineers to have thought of that. It works much better than the carb-mounted switches, plungers and solenoids used on the 1970. :-)
