Go Back   The Supercar Registry > Events > Auctions
Old 03-30-2011, 12:00 AM
Stefano Stefano is offline
Default 1975 Yenko Trans Am
1975 Yenko Trans Am
To be auctioned "With Reserve" at Mecum Indy 2011
Old 03-30-2011, 03:17 AM
Flight427 Flight427 is offline
Default Re: 1975 Yenko Trans Am
1975 Pontiac Yenko Trans Am - Lot F169
<span style="font-weight: bold">To be offered at Mecum Indy Spring Classic
on Friday, May 20 around 4:30pm.</span>
The original owner of this unique 1975 Firebird Trans Am had one goal: to rule over everything else in town, including the ’74 T/A SD driven by the local Pontiac dealer’s son.
With that in mind, he took the Silver ‘Bird to Yenko Chevrolet, where Don and Frank advised him that an L88 427 CI big block would do the trick. The craftsmen at Yenko Chevrolet fabricated the engine mounts, power steering and starter brackets and other hardware to facilitate the conversion, and installed 4.10 gears to maximize the L88’s considerable effect.
The result is this all-powerful Yenko L88 Trans Am, the only one known to exist. With just 13,000 miles on the clock, it is as fresh and powerful as the day it was completed. In the best Yenko tradition, the car’s history is completely documented, including the full ownership trail, title copies, all Yenko receipts and records and a listing in the Pontiac Historical Society.
- Yenko Super Car conversion
- L88 427/430 HP engine
- Extremely original unrestored condition
- Complete owner history from day 1
- 4-speed transmission
- Featured in Super Car reunion
- Registered with Yenko.net
Old 03-30-2011, 03:09 PM
Lynn Lynn is online now
Not denigrating this car at all, because it is a cool car, but here is a classic example of how things get distorted over the years. QUOTE: &quot;The craftsmen at Yenko Chevrolet fabricated the engine mounts, power steering and starter brackets and other hardware to facilitate the conversion.&quot;
I put a 427 Chevy into a kid's 75 trans am back in 1980 (I had put a small block Chevy into his buddy's 240Z and Trans Am boy wanted to one up him). Didn't need to fabricate anything. Got engine stands for an early 2nd gen big block Camaro; measured, located and drilled holes in the Pontiac subframe. No &quot;starter bracket&quot; to fabricate. Just bolt up the starter and use the Chevy support bracket. As for power steering, we just used all Chevy bracketry from a junk yard. Had to relocate the batter (IIRC) and used Camaro tray. All factory parts. Install looked factory. Located all parts ahead of time and did the swap in one day. Could have even hooked up the A/C, but he didn't want it.
Still, a really cool car. Just don't believe there was any serious fabrication involved in the swap.
Old 04-02-2011, 03:50 PM
1969z280 1969z280 is offline
Lynn:
According to the original Yenko Chevrolet Work Order signed by Frank Yenko, they did the following:
Install L88 Engine
R&amp;R gas tank cutout neck for high test gas
Build distributor for engine
Fabricate motor mounts
Fabricate alternat and p.s. brackets
Fabricate accelerator linkage
Rewire alternator, starter and gauges
Install new oil pan and starter nose
Fabricate new gas line
Install 4.10 Gearset
Install Lakewood bell housint
Operational Checkup
This is how the receipt reads. There are also 3 receipts for parts and 1 signed by Don Yenko for the L88 Enagine
Ed
... some old Chevrolets and Pontiacs.
Old 05-22-2011, 11:29 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 1969z280</div><div class="ubbcode-body">Lynn:
Install L88 Engine
Operational Checkup
Ed
</div></div>
Ed:
Guess I missed this post back in April. Again: I hope everyone understands, I am in no way trying to show disrespect for the car. It is a really cool car, and a part of Yenko history. I do know from experience that virtually everything for this swap was available over the counter or salvage yards. Also, changing out a starter nose is a bit different from fabricating starter brackets. Maybe to them, drilling holes in the subframe for Chevy mounts was equivalent to fabricating motor mounts. I am not second guessing the car or the work done at Yenko. Perhaps some of the work was &quot;puffed&quot; just a bit to help justify the cost. Doesn't take ANYTHING away from the car.
Lynn
Old 03-30-2011, 03:19 PM
sYc sYc is offline
I bet according to Yenko they had to fabricate everything.
Tom Clary
Old 04-02-2011, 03:58 PM
When you have work performed at a Chevrolet Dealership, even back in the day, they delineate what was done and charge you for it. I don't feel anything has been distorted over time. Everything stated in the listing is completely documented with the original Yenko paperwork. Ed
Old 04-02-2011, 04:55 PM
bashton's Avatar
bashton bashton is offline
No matter what, that is one Bad-Azzz car. Imagine being the guy cruising around in an L88 powered 1975 Trans Am back then; now THAT is the epitome of &quot;cool&quot;
Bashton
MCACN Managing Member
Bob Ashton
MCACN LLC
Managing Member
www.mcacn.com
Old 04-09-2011, 02:37 AM
Old 05-22-2011, 10:54 PM
CHIP CHIP is offline
So, what happened with your Trans Am? I recorded the Mecum auction and watched everyday except for the tuesday that they added at the last moment. I was rally hoping to hear more about it and see it in action.
