Is there any difference in engine application between a rocker arm with an (L) or
a rocker arm with an (H) ? Thanks in Advance! Ted |
Good morning gentlemen!!
I have tried the Google method(s) on these 2 BBC rocker arms and the responses are kinda all over the place re. the correct dates of SHP usage. L rockers are good for 1965 - 1969 inclusive engine setups. H rockers are good for 1970 and up engine setups. Am I correct or not re. the dates? Thanks! Ted |
There were different rocker arms used for different big block applications over the years. Here's the deal:
"no marking" rockers-----these are most likely aftermarket pieces. Most aftermarket are unmarked. However, I believe that they may also be GM #3860305 which were used for 1965-72 non-SHP applications; "L", "Z", or "X" tip marking----GM #3860308. Used for 1965-69 with SHP and 67-E69 L-88. Also, replaced the 3860305 for SERVICE effective February, 1972; "M"-----GM #6258611-----used for 1973-74 all big block. Also, became SERVICE for 3860308 effective Novemeber, 1972; currently replaced by GM #10112680 "H"-----GM #3959182---used for L69 L-88, all 1969 ZL-1 and 1971 LS-6. Currently replaced by GM #12368082 which is a kit which includes 1 GM #3959182 rocker + ball and nut. There was no "N" that I know of; you may be mistaking a "Z" or an "M" |
The Following User Says Thank You to L72Chevelle For This Useful Post: | ||
lbnaz (07-22-2019) |
Thanks L72 Chevelle re. the BBC rocker arms.
On the 'no marking' rockers, I have to say I believe the arms are GM .. I have a set and they do not appear to be aftermarket issues, but, as you wrote, 1965 - 72 non SHP units. Merci Encore L72 Chevelle Ted |
GM rockers that were not long slot had no markings only rhe long slot rockers were marked. Solid lifter big blocks up to 69 had L and after 69 they had a H. I do not believe there was any difference in the 2
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
Just a note, That was found on the web and sent to me from a friend. Just passing it along not trying to steel credit. Phil
Thanks lads!! Much Appreciated . .
Ted |
Thread Tools | |
Display Modes | |
