1969 NOS ZL1 block casting 3946052 dated 3-1-69 with no stamping on front pad and stamped on underside T 08 0 by flat spot where oil filter spins on. I had new speciality ordered sleeves made for the block and installed.
4296 holley carb dated 893 needs restored. 3946074 aluminum heads dated 8-22-70 & 10-1-70 3933198 intake dated 8-10-70 3975928 aluminum water pump 7115 steel crank standard TRW factory size replacement pistons 7/16 dimple rods Internals balanced and engine is ready to be built. $35,000 I also have a 1968-69 tall deck 4.40 standard bore version of this block as well #3946052 and has a date code of 06017 on backside. Block was pressure tested and ready to build $8,000. Can ship if you cannot pick up. I can be reached at 330-770-2517 for any questions.
Dennis Vugrinovich Last edited by dlv4540; 03-14-2020 at 03:42 PM. |
bump
Dennis Vugrinovich |
bump
bump
