The Ultimate 68 Camaro Restoration Guide
Chick (68 Camaro Z28) with the assistance of Bob Cardillo produced the most detailed and comprehensive restoration document I've ever seen. This is a step by step picture documented restoration, which solves myths, and leave no stone unturned. A big thank you for providing this, and sharing with our members! The stunning finished product... Index is located in the following post.
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:27 PM. |
The Following 13 Users Say Thank You to Steve Shauger For This Useful Post: | ||
67 Nova Boy (04-18-2020), 68camaroz28 (05-01-2020), bergy (04-18-2020), BillD (03-20-2023), camarocards (04-18-2020), dykstra (07-12-2021), HawkX66 (04-18-2020), L78 Fred (03-21-2021), mhm1966 (11-08-2021), napa68 (11-27-2022), SS427 (04-19-2020), X66 714 (02-05-2023), ZLP955 (04-19-2020) |
Index A
Alphabetical Index A
Chick’sTeam Camaro Build Thread - Time for Another 68 Z/28 to be Restored Tableof Contents 68Z-1970 Pictureof Eddie Meadows (orig. owner) – Post32 68Z-1983Purchase - what I brought home in pieces - Post1244 68Z-2010 Howit looked from lacquer paint job in mid-80’s - Post1 68Z-2016 Sawsome sunlight for 1st time since 1979 – Post1263 68Z-2017 Reunitedwith original owner Eddie Meadows – Post1317 68Z-2017 Picturetaking for Hemmings Muscle Machines – Post1348 A-Armassembly painted - Post272 A-Arm rubberflap shields-drilling NOS inner fenders – Post1045 A-Arm rubberflap shields making staples – Post1045 A-Arm rubbermaterial with cords – Post971 A-Arm shims- Post 674 A-Arm upperrubber bumper #384220 -Post 214 Air cleanerconnector #3923260 to valve cover -Post 592 Air cowlplenum air filter A226CW original vs. later -Post 236 &241 Air cowlplenum air filter cheap replacement – Post1191 Air cowl plenumcarb stud – Post 1013 Air cowl plenuminstalled – Post 1191 Air cowl plenumoriginal installation – Post1011 Air cowl plenumoriginal seal – Post1013 Alternator -after restoration original dated 7H10 -Post 148 Alternator -before restoration original dated 7H10 – Post46 Alternatorbrackets - comparing original GT stamp to reproduction stamp -Post 160 Alternatorbracket to header and alternator installation - Post795 Alternatorbracket alignment front vs. rear on alternator -Post 800 Alternatorbracket alignment rear of alternator vintage picture -Post 804 & 806 Alternatorwiring boot original - Post344 Aluminumrestoration, intake and distributor – Post128 Assembly ofcar - rear in subframe in front -Post 454 Assembly ofcowl (Firewall) and under dash list – Post839 Assembly offenders and front end - 1069& 1073 Astroventilation parts and info -764
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:29 PM. |
The Following User Says Thank You to Steve Shauger For This Useful Post: | ||
67 Nova Boy (02-05-2023) |
Index B
B
Ball jointsriveted - Post160 Batterycable negative clips #3857706 -Post 609 & 612 Batterycable negative clips #3857706 located on frame -Post 621 Batterycable negative clips - how to install -Post 682 & 687 Batteryground for Y55 - location and hardware – Post1191 Battery holddown clamp bolt - original with 0.87 inch diameter washer - Post1293 Battery holddown clamp NOS correct piece – Post860 Battery holddown clamp original vs. Service replacement-Post 366 & Post490 Battery holddown clamp original dip painted and stampings – Post1293 Battery holddown clamp painted original survivors (3) - Post511 Battery holddown clamp restored and bolt – Post1183 Battery tray– Post 1273, 1275,1276, 1280,1281, 1283& 1287 Battery traycontinued – Post 1291& 1292 Battery traycontinued - how to make tab correct - Post1304 Battery Y55NOS purchased 1983 (no Energizer script) – Post1183 Battery Y55NOS early 70’s vintage with Energizer script- Post1261 Battery Y55 -How to gut – Post1394 & 1396 Bezels - Sidemarker lights painting grooves black – Post959 Body and componentsmedia blasted to bare metal – Post8, 9 &10 Body rubberflap in rear quarter housings - originals -Post 196 Body work –Post 53, 59,61, 65,69 & 98 Body workcontinued – Post 106& 113 Brakebooster hose bracket-original vs. reproduction -Post 269 Brakebooster restored and hardware - Post155 Brakebooster valve comparisons original to later types – Post814 Brake boostervalve comparisons original to newer reproduction found – Post1306 & 1309 Brakebooster valve and seal #546180 both original -Post 607 Brakebooster valve and seal with original clamp installed – Post902 Brake clutchpedal assembly restoration -Post 410 Brake druminternal components and stamping -Post 258 Brake drumpaint for components - close match -Post 262 Brake drumshoes and assembly -Post 486 Brakeemergency cables with hardware installed – Post1409 Brake hoserubber U-shaped clips - original to reproduction -Post 182 & Post259 Brake hoserear original - Post280 & 302 Brake lineand hardware installed pictures – Post1176 Brake lineclips and hardware (note - ignore bluing for ’68) -Post 524 Brake lineclips and hardware by part number in AIM -Post 541, 543& 545 Brake lineclips and hardware by part number in AIM -Post 587 Brake linerear bracket original vs. reproduction - Post416 Brake linerear bracket with bolt attached to 12 bolt - Post448 Brake mastercylinder (found out later a re-stamp) – Post129 & 796 Brake mastercylinder and booster NOS 5/31/68 – Post851 Brake mastercylinder WT original vs. re-stamp – Post1362 Brake mastercylinder WT original rebuilt and valve with distribution block – Post1365 Brake systemdirectional block and valve restoration – Post852 Brake systemvalve nut re-face (Note valve nut should be phosphate for ‘68, clear zinc for’69) – Post 856 Bucket seatrail for seat in and out - Post304 Bumper frontinstallation – Post1161 Bumperguards NOS – Post 114 Bumper rearNOS guards and installation – Post1151 Bumper rearlicense plate light Bracket installation and light differences – Post1146
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:26 PM. |
Index C
C
Car Show:11/2016 MCACN - Celebrity Pick Award winner – Post1267 Car Show:12/2016 East Coast Indoor Nationals December 2016 - Two awards – Post1272 Car Show:06/2017 Camaro Nationals, Gold – Post1317 Car Show:06/2017 Camaro Nationals judging demerits – Post1329 & 1330 Car Show:06/2017 Camaro Nationals judging demerits – Post1349 Car Show:06/2017 Camaro Nationals judging demerits – Post1355 & 1360 Car Show:11/2018 MCACN 999/1000 and Platinum Pick best stock Chevrolet – Post1382 Car Show:06/2019 AACA Senior award – Post1398 Carb dated7A1 List 4053 – Post 68 Carbmanifold stud – Post1087, Post 1111& 1119 Carbmanifold stud information (Stan NCRS judge) – Post1189 Carb studoriginal ‘68Z - Post592 & 1011 Car cover(have 4 of these) no longer available – Post1157 Chromedoriginal items - Post757 Clutchbellcrank lower push rod -Post 791 Clutch fork#3892632 and spring - Post590 Clutch forkhardware and GM number list -Post 683 Clutch forkspring and rod attachment issue with headers – Post823 Clutch forkspring and rod attachment issue with headers fixed – Post960 Coil springtag Skip’s ‘68Z survivor -Post 540 Consolegages original - Post279 Consolerestoration pictures + (part numbers) and installed – Post1138 Consolespecial nuts #3792287 -Post 691 Cowlinsulation under dash pad (NOS) - purchased 1979 - Post414 & 419 Cowlinsulation under dash pad (NOS) - purchased 1979 restored -Post 449 Cowl insulationunder dash pad rubber plugs original #3868790 -Post 595 Cowl paintedblack - before paintPost 140 & afterpaint - Post150 Cowl paintedbutternut yellow blend in -Post 243 Cowl panelseal #3927464 – Post963 Cowl panel -Z28 stripe dimensions – original - Post3 & 963 Cowl pictureshowing locations clips, lines, speedo, oil, grounds, etc. - Post 719 Cowl reversebackup light wiring to cowl connector -Post 726 Cowl seal#3927464 – Post 62 Cowlstampings PTB Post 692& 698 (green)
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com |
Index D
D
Dash heaterand defroster control panel restoration original -Post 775 Dash installed– Post 1111 Dealershipscript, Roger Dean added to car – Post 1265 Dimmerswitch grommet original -Post 745 Disc brakecaliper original 4 piston -Post 163 & paintedPost 404 Disc brakedistribution block and pressure regulation valve -Post 186 Disc brakehose bracket - Post160 Disc brakehoses (NOS) - stenciled - Post351 Disc brakemounting plate original re-plated -Post 249 Disc brakeshoe kit #5470879 - Post429 Disc brakepressure regulation valve ‘68 to ’69 – Post877 & 880 Distributorcap D308/D308R - Post594 Distributororiginal #1111266 dated 7A25 - Post52 & 664 Distributorvacuum lines - Post581 Door armrest pads, original vs. PUI – Post1080 Door glasshardware – Post1053 Door handlegaskets (NOS) #1154551 -Post 377 Door handleoriginal thickness vs. other years -Post 326 Door handlere-chromed and #9709600 push button -Post 374 Door handleready for installation -Post 700 Door hingearea painted – Post 20 Door hingebolts (3 different manufacturers) - Post20 Door keylock and gaskets - Post809 Door keylock original vs. Service replacements - Post1379 Door latchoriginals and door latch rod covers - Post508 & 1053 Door latchespainted – Post 1068 Door lightswitches - original -Post 700 Door lock originalpush knob – Post365 Door mirrortaking glass out for re-chrome -Post 585 Door mirrororiginal date code 10-DMI-7 - Post43 Door mirrororiginal restored and installed – Post1161 Door rubberbumpers - original -Post 700 Door rubberbumpers (NOS) #4721222 – Post1094 Door sillplates (NOS) with rivets purchased 1979 -Post 810 Doorweather-stripping (NOS) – Post1134 Door windowcranks - Post 540& 567 Door windowcranks assembly after re-chrome – Post881 Door windowfuzzies - https://www.camaros.net/forums/3414713-post1077.html]Post 1077[/url] Drag linkoriginal blued - Post208 Driveshaftpaint markings after Evaporust bath -Post 271 Driveshaftpaint markings installed – Post1409 Driveshaftyoke - paint markings -Post 285 & restoredPost 426 Driveshaftrestored - Post322 Drum brakehardware - Post 393& 395 Drum brakewheel cylinders rear -Post 276
Index E&F
E-F
Emblems -fender (NOS) 302, bezel and Camaro – Post959 Emblems -fender original 302 emblems Eddie had taken off car late 60’s – Post1317 Emblems - trunklid Fisher #7752901 - Post1361 Emergencybrake cables - Post401 & hardware413 Emissionssticker radiator support – Post1187, 1188,Post 1238 Engineassembly #3830711 head gaskets, pistons, heads, etc. -Post 506 Engine cam,Crane blueprint specification – Post1130 Enginecompartment original ‘68Z (cook_dw) with air cowl plenum - Post1004 Engine dressup starting - Post 582& 608 Engine dynosheet - Post 531 Engine headbolts original - Post481 Engine mount#6258154 (not correct purchased 1979) -Post 484 Engine mountcorrect - Post 500& Post 505 Engine mounthardware original vs. reproduction - Post482 & 539 Engine oil pandrain hole “TR” bolt - Post43 Enginepainting at plant picture -Post 646 Enginepiston original - Post412 Enginestamping pictures -Post 168 Engine withtransmission going in subframe -Post 735 & 736 ExhaustGardner installation – Post1168 Exhaust pipehanger rear originals - Post554 Fan shrouds,original vs. (NOS) Service replacement – Post1087 Fender sidemarker bezel differences – Post70 & 71 Flashersignal Stat 175 - Post783 & 785 Fuel pumpAC40524 used on ‘68 Z/28’s – Post1260 Fuel pumporiginal bolts - Post201 Fuel pumpplate, black or bare metal – Post872 Fuses colorcoded – Post 1294
Yay!
This should definitely be a published book!
The Following User Says Thank You to bergy For This Useful Post: | ||
68camaroz28 (04-18-2020) |
I agree Bruce, and a huge thank you for contacting me to initiate this thread!
Thanks to Bruce for relaying on to Steve and special thanks to Steve for the kind words and placement on this great website. Also as you mentioned Steve in the beginning my friend Bob (aka camarocards) was instrumental after I completed the table of contents adding all those links. It became a real team effort!
Thank again, Chick
68,69&2015 Z/28's 69 L78 Nova Purchased new 32k miles 69 Restored Nova L34 Father/Son Few Corvettes Our 68 Z/28 Build thread- http://www.camaros.net/forums/showthread.php?t=182584 |
The Following 3 Users Say Thank You to 68camaroz28 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
