freedom battery
just finishing a restoration of a COPO camaro and understand that with my build date of June, a freedom side post battery and cables should be installed , the only situation a top post style would be used is if the HD 63 Amp. alternator option selected.
Does anyone have info on this topic and/or where to source these, i'm tryting my local GM dealer as it said in a previous post that GM had not licenced the battery out to anyone |
Re: freedom battery
Not exactly.
K79 [42 amp] and K85 [63 amp] alternators were not available with mechanical lifter engines. If the car was built with the T60 heavy-duty battery it would have been a top-post.
Re: freedom battery
ok, it doesn't have the U60 option listed on the GM of Canada documents so that means side post as i read in the McNeish book?
Re: freedom battery
Correct. It would have been built with a Delco R79 side-terminal battery.
http://www.camaros.org/underhood.shtml#Batteries
Re: freedom battery
William is correct . The correct battery is an R79 Delco Energizer. I was under the impression that Freedom Batteries were introduced in 1976?
Here's what the correct battery for your COPO looks like. |
Re: freedom battery
http://seattle.craigslist.org/see/pts/5137014737.html
not exact but it is a side post. Jim(Not Mine)
69 Los Z11 68 SS/RS 396/325 68 Los Z28 |
Re: freedom battery
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 169indy</div><div class="ubbcode-body">http://seattle.craigslist.org/see/pts/5137014737.html
not exact but it is a side post. Jim(Not Mine) </div></div> Low power battery. Might start a six cylinder car.
...................... John Brown This isn't rocket surgery..... |
