Muncie ID
I picked up a couple of muncies and I would like to determine as close as possible what the original application was. I posted this over on the Chevelle site, but thought I'd try here as well.
The first is: 3925660 Main Case 3857584 Tail Shaft P9S23A Code VIN# 19Z322076 Two rings on input shaft 10 Spline Input 27 Slpine Output Tag on side 3870358 The Second is: 3885010 Main Case 3857584 Tail Shaft P0713 Code VIN# 6S126722 Two rings on input shaft 10 Spline Input 27 Slpine Output Tag on side 3870354 TIA, Jon |
Re: Muncie ID
"This is Sheriff Buford T. Justice, I'm in pursuit of a black Trans Am, he is all mine so stay out of the way" |
Re: Muncie ID
The first trans will fit on a 68 /69 passenger car, Vette, Nova, Camaro Chevelle. Should be a M20 Wide Ratio.
The second fits the same but a 66 / 67. |
Re: Muncie ID
Both are M20's - the first one is out of a '69 Chevelle built at Fremont, California, and the second one is out of a '66 Corvette (St. Louis).
'69 Z/28 Fathom Green CRG |
