Old 09-17-2008, 10:43 PM
Rainer Rainer is offline
Default Lots of 68-72 Chevelle parts
Lots of 68-72 Chevelle parts for sale. These are all good quality parts. Here’s a partial list of what is available:
Interior parts
- 69-72 door panel cores, these are the metal uppers, $10 each
- 70-72 front arm rests, black and several other colors, all in nice shape, mounting screws included, $15 each
- 70-72 rear arm rests, black, vinyl-covered metal ones (not plastic) that were in 70-72 Monte Carlos, direct swap into a Chevelle, $40 pair.
- 70-72 front stereo speaker brackets, $25 a pair
- 68-72 inside A-pillar cover, no rust at the lower corners as is common, $15 each
- 68-72 black kick panels for AC cars, $30/pair
- 70-72 front windshield or rear window inside trim, nice with no cuts from glass removal, black and several other colors, $25 each
- 68-72 rear window lower corner pieces; these are the small plastic pieces that are always cracked or broken, $30/pair
- 68-72 gas pedal assembly, $10
- 70-72 dash ducts and vents, $5-$25 each, for both AC and non-AC dashes and SS cars
Exterior trim
- NOS 70 Chevelle rear bumper guards still in the GM box (will not fit SS cars), $75/pair
- 70 grill stainless trim, original GM pieces. These are the C-shaped ends. Set of 4 for $40
- 72 headlight bezels, no pitting, $30/pair
- 68-72 front windshield stainless, driver quality with only a minor ding or two, $10 each side piece, $20 for top piece
- 68-72 rear window stainless, driver quality with only a minor ding or two, $15 each piece
- 68-72 drip rail corner pieces. These are the ones at the top of the A-pillar, $5 each
- 68-72 drip rail A-pillar stainless trim, runs down the pillar between the windshield and door glass, driver quality with a couple small dings that could be easily taken out, $10 each
Miscellaneous parts
- 70 only NOS key blanks, set of ignition/door and trunk/glovebox (2 keys total), $6 includes shipping through USPS standard mail. Add a second set for another $4
- 68-72 power steering box with pitman arm, just over 3 turns lock to lock, $50
- 69-72 ignition lock with key, $5
- 68-72 door locks, pair, with key, $10
- 71-72 Delco wiper switch, $10
- 68-72 trunk latch, with mounting bolts, $10
- 71 and 72 taillight lenses (they are different), $10 each
- 71 and 72 taillight lenses for standard or Heavy Chevy models, with no silver trim, $15 each
- 68-72 rear control arm braces, sometimes referred to as F41 braces, $50/pair
- 68-72 wiper linkage assembly, all joints/sockets in good condition, $30
- 68-72 license lamp housing and lens, $10
- 71-72 headlight housings (cast aluminum), $35 each
- 68-72 front lower control arm original GM mounting bolts with nuts, set of 4, only light if any rust, $8/set
- 68-72 power steering box original GM mounting bolts with thick washers, set of 3, only light if any rust, $6/set
- 68-70 factory Muncie 4-speed bench seat shifter handle with GM part number stamped into it, needs to be rechromed but ball threads are good, $75
- 70-72 door latches, good working condition, $15 each side
- 70-72 door window regulators, good working condition, $10 each side
- 70-72 quarter window regulators, good working condition, $10 each side
- 68-72 rear frame crossmember, nice straight piece for replacing that bent-up piece on your car, has been cut off past the frame rails so you can trim and swap in at the factory seams, $60
- 68-72 upper front control arms, no road salt rust, $25 each
- 68-72 lower front control arms, oval rear bushing, no road salt rust, $35 each
- 68-72 upper rear control arms, no road salt rust, $10 each
- 68-72 lower rear control arms, no road salt rust, great pieces for boxing up, $20 each
- 70-72 door glass, driver quality with “normal” scratches, $15 each
- 68-72 door hinges, $15 per side (upper and lower)
- 70-72 front bumper filler panel, $60
- 68-72 gas tank straps, these are straight, rust-free originals with the correct stepped and narrowed ends (the current GM replacements are different), $45/pair
Parts will be shipped for actual cost through FedEx ground. Paypal OK if you don't mind covering their fees. Otherwise check or MO is fine. Email me at [email protected]. Also have additional parts not listed – just ask.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 09-18-2008, 05:38 AM
Default Re: Lots of 68-72 Chevelle parts
Rainer
Any F-41 front or rear swaybars?
Old 09-18-2008, 06:08 AM
Donnie's Avatar
Donnie Donnie is offline
have you got a 70 BB power steering hose?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 09-18-2008, 09:38 AM
Sorry guys, no F41 sway bars or BB ps hose
