I'm gonna be looking for a new trans for the Nova.The old one is toast,broken ear on the case,used up gears and syncros.More to rebuild it right than to buy new with the good stuff in it.The trans that was in it I beleave is a M20 with 2 rings on the input.Wouldn't mind a M22 with a supercase.That would do everything that I could throw at it. Any advise is appreciated.
Thanks in advance. Kendall ![]()
70 Nova SS ZZ427 TKO600 5speed 3.55Posi |
If I had it to do over, it would be an M22 in the new case with the Italian gears. Let's see who can get the website first. I heard they had new ones for 1800. If numbers matching doesn't matter...
Complete new Muncie M22 1775.00 No core charge http://www.tbtrans.com/muncie_4_speed.htm#new_unit All of our Muncie units are built with the new muncie supercase, super tailhousing, and the masiero italian gearsets, we also use the new iron center midplate,along with the roller bearing sidecover making this unit the toughest thing on the street!!!!!!! |
I'm tossing this idea around too. I have the original M-20 trans in my 69 ElCamino, but if I were ordering the car new, I would have ordered the M-22.
I think I'll put the numbers matching trans on a shelf and stick a new M-22 behind the L-78. Gonna have to get a new clutch disc, and input shaft, but thats no big deal. Everything else, like the shifter, pressure plate, mount, etc can be reused. |
Chris,Thats the one I was thinking of,but wanted some more input.Gonna pull the trigger within a month so doing some shopping.
Kendall ![]()
Like Bill says, putting my original trans on the shelf would have been smarter 5 or 6 years ago. Now, just finished the second major repair/rebuild and I've been advised to "take it easy". That's going to be difficult with a new LT1
I purchased an M-22 Supercase Muncie a couple of years ago for my current Biscayne. The main reason I went with it is because of all the cars I've owned in my life, I've never had one with a real Rockcrusher in it. That was a missing part of my life that needed fulfillment! Now.......I don't know how hard you have your heart set on a new Muncie, but I do know that the next transmission that I buy will be a Tremec TKO 600. It's got the lower First gear AND an Overdrive in Fifth. You can put a stock style shifter on them, they are very reasonably priced, and nobody but you knows that it's in there! I've just heard too many good things about those Tremecs and everybody seems to often say that it was the single best modification that they've ever done to their car. Not trying to talk you out of the Munice, just some food for thought.
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
If you have to have a Muncie, go with a set of M22W Italian gears.
With the right set of rear gears it's better on the street/highway but you still get the strength of a M22.
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
I purchased an M-22 Supercase Muncie a couple of years ago for my current Biscayne. The main reason I went with it is because of all the cars I've owned in my life, I've never had one with a real Rockcrusher in it. That was a missing part of my life that needed fulfillment! Now.......I don't know how hard you have your heart set on a new Muncie, but I do know that the next transmission that I buy will be a Tremec TKO 600. It's got the lower First gear AND an Overdrive in Fifth. You can put a stock style shifter on them, they are very reasonably priced, and nobody but you knows that it's in there! I've just heard too many good things about those Tremecs and everybody seems to often say that it was the single best modification that they've ever done to their car. Not trying to talk you out of the Munice, just some food for thought. [/ QUOTE ] I agree! The M22's even with the new gears and so forth are really not that strong. Besides I don't think the new Italian gear M22's whine like the old days. Tremec, used Jerico etc. ![]() |
My M22 Italian gears did whine but not very loud.
I have done some research on the M22W gears and they are supposed to handle 600HP...I guess I'll find out when I use them! ![]()
I have 2 m22 one is from a 1970 camaro and its all original
with about 20 thousand miles on it. the other one is an m22 also but with a new italian input shaft and what a difference. My m22 thats in my L78 chevelle is not orig to the car and I have the real one on the shelf.This orig Camaro trany howls just like a 747 jet flying over your head at 50 feet.The other one with italian input shaft is no where near the same noise. LOOOOOOVe it!!! PJ |
