Would someone please post (again) a list of best lubricants. It was a best to worst list based on torque required to break the bolt free. It included wd40, pb blaster and a bunch of other concoctions.
Thank you [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Sam... ![]() |
Kroil, pb blaster, wd-40
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue |
Someone once told me that the best stuff is not even made. Testing was done and I would love to have some real world testing by someone that I know. The witches brew is a half and half mixture of acetone and ATF. Someone willing to try?
Snarl softly and carry a big stick! 1969 Hurst/Olds 13.26 @ 103.12 Pure Stock Rusty Small |
Kroil works very well!!
Dave 67 Nova Boy |
Sam, Power Blaster always worked for me but it's not always a 100% remedy... Saturate the bolts/area and let it sit overnight and then try it..
OR I'm not sure which manifold bolts you are referring to.. But you could try putting a little heat on them.. Just have to be sure you don't snap em' off when screwing them out, GO SLOW.... Then it's drill out time!!! Been there done that.... [img]<<GRAEMLIN_URL>>/no.gif[/img] Rich
"This is Sheriff Buford T. Justice, I'm in pursuit of a black Trans Am, he is all mine so stay out of the way" |
If exhaust manifolds to head bolts, depending on what engine sometimes it's better to torch the heads off and slip the manifolds off over the bolt..
With the manifold off you can access the head with heat and using grips or good quality battery pliers on the protruding stud and heat where they thread into the head they can easily turn out and a whole lot better than playing stud extraction games w/ broken bolts.. If flange bolts, heat your nuts!. Anyone here ever try the candle wax trick?. Good luck!. [img]<<GRAEMLIN_URL>>/beers.gif[/img] ~ Pete
I use the candle wax method all the time and it works pretty damn nice. Ever try getting a steal heater hose fitting out of an aluminum intake? I could never get it out without cracking the aluminum until I tried the candle wax and it worked great. Now I use it all the time.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
Rick just likes playing with fire.... [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Bruce Choose Life-Donate! |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">I use the candle wax method all the time and it works pretty damn nice. Ever try getting a steal heater hose fitting out of an aluminum intake? I could never get it out without cracking the aluminum until I tried the candle wax and it worked great. Now I use it all the time. </div></div>
Thanks for the tip Rick!!!!! I just removed 3 plugs/fittings out of a aluminum intake and the wax method worked GREAT. Kurt [img]<<GRAEMLIN_URL>>/beers.gif[/img]
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
Thanks all. Rick can you elaborate on the candle wax method? [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Sam... ![]() |
