I picked up an engine yesterday and thought I would share. It is a complete L-88 engine that was built by GM with cast iron heads. The cast head L88 is a subject I have always been interested in. I have seen a few pop up over the years and mos message boards seem to dismiss the engines as being home built or L71/L72 engines with a 3933198 intake added.
This engine was removed from a 1969 speedboat and was the original engine to the boat. It was running 2 days ago. The suffix code is 7BL. I have seen this suffix before and always wondered what it was. The engine has the correct 3933198 intake, 840 heads, heavy duty AC fuel pump, 7/16 dimple rods, and the 7115 steel crank. |
Here is the engine as it was pulled. The carb is a 3246 service dated Holley. I have seen 3246 carbs on most marine 427s. The pulleys are GM units but are not deep groove.
The block is a 3963512 casting with a casting date of B 5 9.
![]() ![]() The heads are both 3919840 with casting dates of A209 and C139. ![]() ![]() ![]() |
The front pad is stamped TO3177BL. The 7BL suffix must mean closed chamber L-88 with cast iron heads.
![]() The 3933198 intake is dated 9.18.68. I believe the 198 intakes were only made in certain runs. I don't think I have ever seen a casting date from October 68-Feb 69 unless the 198 was hand stamped. ![]() ![]() |
Factory high lift rockers are still intact.
![]() L88 pushrods still there ![]() |
Cool original fuel pump
Pulling the pan was exciting. No denying this is a L-88
I decided not to pull the heads since the engine runs great and I can see it is standard bore due to the TRW pistons having GM and the part number on the undersides.
neat find. im really surprisd at the carb. most OE marine carbs have 180 degree vents. having worked at a boat dealer ive never seen one like that factory.
we had at least 4 early 70's BB chevys and fords and the carbs all looked like this ![]()
1973 Corvette Coupe "Motion Customer car" 454/TH400 1968 Chevelle Concours sport coupe |
----Since the carb is service dated I would guess that the owner or mechanic bought an automotive carb when the boat carb went bad. It was probably cost effective at the time, but not too safe......Bill S
