I was talking to a rep at jet hot coatings and he said that coating the stock exhaust manifolds would bring the heat the engine area bay down 20%. That's kind of hard to believe. Has anyone every had their manifolds coated and what was your experience. I know they look good but as far as engine bay being cooler, I doubt it.
20 degrees of temp, maybe. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
![]() COPO 9561/9737 M40 X11D80 13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22 |
The temp should drop a little. When JetHot coats headers and exhaust manifolds, they coat the inside and the the outside. The inside coating helps get the hot exhaust flow better. That should help keep the temp down some.
James
1968 Beaumont SD396 |
I had the Hooker Headers in my Z28 done by a company called Calico. You can run the car for hours and touch the headers immediately after. While I do not suggest doing this, its the only way to adequately explain how cool the headers are.
http://www.calicocoatings.com/indust...motive-racing/
Follow me on Instagram: https://www.instagram.com/mbcgarage/ |
Do you remember the cost
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79 |
At least 400... Maybe more. I dont remember exactly
Thanks
I had my 69 Z done in 96 they are still holding up not really sure if they run cooler.
