Brand new never fired. We have already added a better carburetor. New Holley 850, 105 amp Delco alternator, mini high torque starter plus pulleys, power steering pump and brackets and even an A/C compressor. #252 of 427 made, Asking 23K obo.
19166392 To celebrate the 50th anniversary of the Chevrolet big block, GM Performance Parts has brought back a modern version of the ZL1 for your chance to relive muscle car history. The Anniversary Edition 427 starts with a retooled version of the ZL1 aluminum block using the exact same tooling that helped create this legend in 1969.The advantage of the aluminum block is that it offers the completed engine the weight of a small block with a whole lot more power. With a full list of features, this modern ZL1 is one of the most exclusive big block crate engines ever offered by GM Performance Parts. Fittingly, only 427 will ever be produced, and then the ZL1 tooling will be retired forever.The 427 lucky owners of this commemorative monster can expect an estimated 480 horsepower and 490 lb-ft of torque. The legend of the all-aluminum big-block continues. Part Number 19166392 Limited production ZL1 Heritage To celebrate the 50th anniversary of the Chevrolet big block, GM Performance Parts has brought back a modern version of the ZL1 for your chance to relive muscle car history. The Anniversary Edition 427 starts with a retooled version of the ZL1 aluminum block using the exact same tooling that helped create this legend in 1969. The advantage of the aluminum block is that it offers the completed engine the weight of a small block with a whole lot more power. With a full list of features, this modern ZL1 is one of the most exclusive big block crate engines ever offered by GM Performance Parts. Fittingly, only 427 will ever be produced, and then the ZL1 tooling will be retired forever. The 427 lucky owners of this commemorative monster can expect an estimated 480 horsepower and 490 lb-ft of torque. Anniversary Edition 427 Tech Specs: Engine Type - Aluminum Chevy big-block V-8 Displacement - 427 cu in Bore x Stroke - 4.25 x 3.76 Block - Cast aluminum with 4-bolt main caps Crankshaft - Forged steel Connecting Rods - Forged steel Pistons - Forged Aluminum Camshaft Type - Hydraulic roller Valve Lift - .510 intake / .540 exhaust Camshaft Duration (@.050 in) - 211° intake / 230° exhaust Cylinder Heads - Aluminum oval port, 110cc chambers Valve Size - 2.19 intake / 1.88 exhaust Compression Ratio - 10.1:1 Rocker Arms - Aluminum roller style Rocker Arm Ratio - 1.7:1 Distributor - HEI type Carburetor - 870-cfm Water Pump - Aluminum short style Spark Plugs and Wires - included Flexplate - 14" Recommended Fuel - 92 octane Ignition Timing - Base 8° BTDC, 36° Total Maximum Recommended RPM - 6000 Balanced - Internal
Micky Hale Hale Performance Consultants Engine Parts Sales & Service |
Bump, lower price, $18,500 OBO.
new price, want to sell $18,500 with all accessories
Hi , we're these engines still based on the mark IV 2 piece rear main seal or the later gen 5 or 6 with the one piece rear main seal ?
It has the 1pc rear main.
