Old 04-30-2017, 01:22 AM
the427king's Avatar
Default 67 chevelle master/booster #s
nEED STAMP COPDE FOR 67 CHEVELLE DISC MASTER AND BOOSTER #
No Fisher priced toys here
Old 04-30-2017, 05:04 PM
Booster is a 9820 and the master carries an SA stamp.
Pretty rare master.
Old 04-30-2017, 06:07 PM
the427king's Avatar
thanks what would the prop valve etc setup look like same setup for 68 chevelle i assume and possibly same as 67 68 camaro? at least visually//
Old 04-30-2017, 06:59 PM
Yes, the same as Camaro. Everything up top uses the same configuration. The rotors and calipers are the same also, just the inlet to the brake lines at the calipers were different.
If you want, you can check out my TChevelle ad, I've got a nice complete unit listed off a '67 chevelle.
Old 04-30-2017, 10:02 PM
the427king's Avatar
Im pretty sure the casting number on the caliper halves are different from chevelle to camaro?
Old 04-30-2017, 11:44 PM
I can't say, but you may be correct on the calipers. I know there was a different inlet position but I'm going by hearsay on that and have never compared the calipers side by side. I was thinking it was a fitting that changed the line position, but it could quite possibly be in the casting which would be a different part no.
Old 05-02-2017, 01:07 AM
These are original 1967 Chevelle Disc Brake Assemblies
Old 05-02-2017, 03:48 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
What's the casting number for the Chevelle master cylinder? Is it a "346" like the Camaro one?
Old 05-02-2017, 08:26 AM
Master cylinder casting # 5460346, 1967 Chevelle part# 5469489, code SA.
Old 05-03-2017, 01:47 AM
1967Z28's Avatar
Great info. Thank you.
