Old 10-14-2017, 01:27 PM
bergy's Avatar
bergy bergy is offline
Default pitman arm - fast ratio 227 PS wanted
Anybody have a fast ratio pitman arm that they are willing to part with or trade for a manual arm? Pictures of manual - nice part.
Attachments - The Supercar Registry pitman arm 227 2.jpg pitman arm 227 1.jpg DSC01280.JPG DSC01279.JPG
Old 10-17-2017, 09:58 PM
bergy's Avatar
bump
Old 10-30-2017, 02:14 PM
bergy's Avatar
bump
Old 10-30-2017, 03:23 PM
6667ss138 6667ss138 is offline
Bergy, I guess I'm confused as to which pitman arm I have. Its hard to read the casting number on the one you have pictured. Is it 3953327 BGMT5?
Mine is 3953227 GMT1B. It is on an early 69 manual box that I have had for years so I assumed it was correct for a manual.
Thanks!
Old 10-30-2017, 05:59 PM
Steve Shauger's Avatar
Administrator
Thanks!
The pitman arm 227 is the quick ratio, and used on both manual and power steering, however the PS arm has a much larger splined hole. Again the casting # is the same, but the power and manual arm are not interchangeable.
www.yenko.net
www.vintagecertification.com
Old 10-30-2017, 06:42 PM
bergy's Avatar
Steve is correct (of course) - larger hole on the PS arm. Also, sometimes has a "P" stamped by the hole.
Old 10-30-2017, 07:14 PM
Thank you Gentlemen!
Bergy, Now that I know what to look for I do have two more pitman arms that I will check as soon as I can get to them and if one of them will work for you I will get back with you.
Old 10-31-2017, 12:49 AM
ssl78 ssl78 is offline
I have this one it is very good shape with no play. It doesnt have a P or M stamped it has a double hash mark, but it measure more than a inch in diameter at the box end.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 10-31-2017, 02:42 PM
bergy's Avatar
My parts are in PA and I'm not there at the moment. Can someone confirm "greater than 1" on the box side" is the PS arm?
Old 10-31-2017, 10:37 PM
L78 Fred L78 Fred is offline
Default Pitman
Bruce,
I can send you any picts and measurements you need of fast ratio PS Pitman arms from my 04 C L78 Pace Car
Regards,
Fred Schempp
610-585-4155
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
